I bought a regular cheap ntsc camera from AliExpress for testing, prior to buying something expensive.
i suppose that you have MIB2 system.. where did you plug video cable?
do i need to buy?:
car-interface.com/vendita/en/reverse-camera-input-seat/882-seat-mediasystem-plus-mib-reverse-camera-input-interface.html?search_query=MIB2&results=12
Can you tell me what car are you talking about ? Model and year ?
I think same as yours... Leon 2017 ST FR with 8" MIB2
Than you don’t have to buy this interface.
Did you read this thread from the beginning?
It contains all the information that is needed to install the RVC.
If you don’t understand something, I will help you
Highline camera now works in my 2014 FR
Some pic's:
https://www.upload.ee/image/8640289/Untitled.jpg
https://www.upload.ee/image/8640298/IMG_5186.JPG
You need to look for an NTSC output.
I use this one and works fine.
www.amazon.co.uk/gp/aw/d/B012FQZ0A6/ref=mp_s_a_1_2?ie=UTF8&qid=1506448659&sr=8-2&pi=AC_SX236_SY340_QL65&keywords=reverse+camera+ntsc&dpPl=1&dpID=41ANHGo0MsL&ref=plSrch
Sorry for late answer...which camera did you use ?
i want to retrofit this to a mib2 unit
can this be used
https://www.aliexpress.com/item/Hig...5505-46f1-86e2-b25757108d1a&priceBeautifyAB=0
or try and build a cheaper version of this
http://vagtec.co.uk/eshop/genuine-seat-oem-retrofit-kit-rear-view-camera-leon-5f.html
I used 5Q0980568A camera, bought from this site http://vwmodul.de/
Can highly recommend these guys!
i am pretty sure highline cameras need to be paramertized before they work properly you sure only vcds ?I used VCDS, but I think you can do it with OBDeleven also.
Seller did parametrization and coding before sending it to me, then I used VCDS to make some changes for it to work correctly. Parametrization has to be made for VW, Škoda parametrization did not work for me.i am pretty sure highline cameras need to be paramertized before they work properly you sure only vcds ?
i thought it needed itSeller did parametrization and coding before sending it to me, then I used VCDS to make some changes for it to work correctly. Parametrization has to be made for VW, Škoda parametrization did not work for me.
