running 10 psi?
Cupra_Wob
had my car on the rollers at torque of the devil (dyno dynamics rollers) and my car reached 200.4 at the flywheel and 190lb/ft at 10 psi why is it running so low shouldnt they be 14 psi with a just a remap?, anyone with any help why it is running 4 psi left when my map should be atleast 14psi?
AndyHazza
Ex-Awesome GTi Staff
Mar 30, 2005
1,455
Bolton
www.awesome-gti.co.uk
Hmmm very bizzare :think:
I just noted though that you had added the figures, the torque seems a little low, mine used to hit 220ftlbs with just a remap on and 190bhp. :think:
Cupra_Wob
Yer it weird, maybe i just need another map? or is there any other way to bring it back up to how it should be.
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
yeah well 'most accurate' dont cut it. no dyno is 100%
most of the time cars dont even hit 200 without an fmic, and those tha do usually have alot more mods and will be running well, thats 15-21psi on a spike. plus if torque was down then power would relate...thats just physics
it really all depends on where it produced 10psi... if that was the max it hit then somethings wrong
Cupra_Wob
They are the best rollers out there, thats why we went there, it was 10 psi max boost mate, and i do have a FMIC, ill upload the graph tommorow so you can see.
acidstrato
Dec 9, 2004
5,942
sorry when u said just a remap in the first post i figured thats all you had.
what fmic is it? notice u got k03s aswell, i'd still confirm the boost, dont be so trust worthy lol dyno's are only as good as the operator.
and if you find it is only producing 10psi then then the logs will give you a good indication of what is the problem
Allen
He has a k03s, cat back exhaust (all be it only a powerflow) THS FMIC, TIP, 007p im pretty sure thats all the mods. Chriss Todd was running the rollers, one of the biggest names in the Ford tuning world.
Cupra_Wob
Yea my mods are:
K03s
THS FMIC
AmD map
Cat-back
Jabba sport air filter
Forge TIP
007p
Ill get the Vag-Com out and check. cheers.
acidstrato
Dec 9, 2004
5,942
the name means **** all since these cars aint fords....
are you on commission or something?
dynos aint accurate...end of
acidstrato
Dec 9, 2004
5,942
yeah could be, or n112, n75, maf or just a split vacuum hose
could be anything really
or it could be that the dyno didnt measure it correctly
just get it on vagcom if you have your own and log
Cupra_Wob
Heres the graph
