Ive got Low Pass Filter and High Pass Filter built into the amp, crossover slope LPF/FULL/HPF , remote bass control, gain control and its 2ohm stable, so i can i think, wire it up to 2 Subs
All I need is some decent speaker wire to connect the Sub to the Amp. Any suggestions on that?
Also, mounting? i was going to have the sub facing out (towards the back of the car), in the right forward corner(nearest to the seats on the right side of the boot), and mount the amp above it, on the back of the rear seat. Sound okay?
Also, the amp has a remote start, does that mean that aswell as the RCA cables, you wire the remote wire to the headunit, so the amp only powers up when the headunit is turned on?
Thats my only concern so far, that and getting the cable into the cabin, from the battery, and where to mount the fuse, and the ground.......![]()
I'm trying to reply on my ipod so apologys if it doesnt work.
Make sure you put fuse as close to battery as possible
Yes you need to run remote as well as rca, remote is the blue wire
Amp can go anywhere where it wont get to hot because heat rises and it will cook itself (dont mount it upside down)
Earth you can take from the boot
