Status
Not open for further replies.
HTC
Sep 2, 2004
421
Cool. Just looking out for you guys.
S3/LCR pump should be okay for gt2x power levels. Mine however wasn't.
RobDon
Pro Detailer
My thinking too, I'm not comfortable relying on a 7-year old OE pump, running larger than standard injectors at 4-BAR, APR fit uprated pumps on their 290bhp stage 3 kits, I'm up around the same so for my own peace of mind the Walbro is in, plus it will serve a purpose when going bigger turbo, bigger injectors, etc. in the future.
I'd much rather be well within the limits of the Walbro than right on the limit of the OE pump.
jamiebennett81
hmmmm ok
will look to be fitting mine then when i get it back off Will
although, will this affect the way the car fuels at all? or just better built for higher end applications
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
reggy determins rail pressure, mapping determins injector duty cycle, so unless it was mapped with an underperforming base fuel pressure (and you would be none the wiser if it was !!) it should have no effect on running
jamiebennett81
is that something you could check when I come up do you think...check fueling and timing etc?
jamiebennett81
Why? Convert to the other side and you'll get a better FMIC/pipe runs in there...
I dont think the re routing would be that difficult in essence of the LC cars....just a few more pipes and bends adding
RobDon
Pro Detailer
Latest progress, managed to get the SEM manifold fitted today, alot still to do as far as re-routing all the intercooler pipes, hoses etc. but the manifold is on and the fuel rail is on.
http://i312.photobucket.com/albums/ll330/SonicBlueLeon/seminstall1.jpg
http://i312.photobucket.com/albums/ll330/SonicBlueLeon/seminstall2.jpg
All went on with no hassle, lots of little things to move but so far it's been quite easy. Have to buy some new silicone elbows and alloy bends but I already have most parts to complete the new hotside pipework.
While the coolant is drained off (I have to remove the swirl pot to make way for the TB and pipework - doh!) I'm going to fit the oil cooler at the same time as I'm doing the IC pipework.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Looks very purposeful there, means buisness;)
Will be interesting to see how much more you can get out of the turbo with all this fitted and a custom remap
Has your faith in Star been revitalised?
jamiebennett81
does not look that difficult to re route the pipe work either for the FMIC, just a U bend and go back on itself I imagine?
RobDon
Pro Detailer
I've come back to updating this thread as it's gone off the topic of my blown turbo in the big turbo section.
Hopefully fitting my new carbon door mirrors today, so will update new pics of carbon bonnet, pins and carbon mirrors.
Status
