Yeah, although no fault codes at all it was sending my boost crazy, overboosting to 1.8 BAR! Might try the Bailey DV26 instead.
Just had a look through all your pics mate. How many dv's have you had? I must of counted 4 or 5
yes - show me
Plastikote metallic silver and Wurth acid etch primer, 2 coats of each. Very easy paint to use, goes on well and dries quick. I saw it on a Ford Escort Cosworth rebuild thread and the guy used it on his gearbox etc. and it looked great.
Got my USRT Walbro pump installed today, pretty easy with the wiring harness, the hardest part was hooking up the yellow wire to fuse #28, which powers the OE pump relay. Now it's all installed you can hear the Walbro priming up when you open the drivers door, same as the OE pump!
Next job is the Mocal oil cooler.
