Rob are they Cupra or Cupra R wishbones? if you don't mind me asking how much were they? I'm thinking of doing what you have done.
Nice figures to![]()
Yes, as I have a Cupra they are Cupra wishbones.
but wouldn't the new turbo benifit from all the other mod you've done and shiny parts and be achieving nearer 400 with the right mapping?![]()
Yes but I don't want to turn my car into a wheelspinning monster which is a total waste of time. I like the idea of the ball-bearing turbo though as spool should be much quicker than it is now, making for a quick responding setup with a good, usable powerband. One reason why I went for the GT2860RS and not anything bigger, I feel it will be plenty for a FWD car.
Thank god I am not the only one who noticed this. When the falkens were newish you could feel diff working a lot more. Soon as they reach 50% you lose all feedback from the tyres.The level of dry grip is huge, I can actually feel the Quaife diff working on corners now where before the Falken tyres would be scrabbling for
.......re-read what you quoted Bill
(Rob calculated 317.5, it made 317.3!)
In all honest I doubt my car is making 340bhp but just going by what happened last time, 219g/s scaled it made 317bhp @ 1.5 BAR, it's now making 236g/s (scaled is 273g/s), since last dyno run it has JBS manifold, ported head, Fluidampr crank pulley, big Forge FMIC instead of cheap ebay one and 1.7 BAR of boost.
Turbo is being replace very shortly anyway.![]()
Rob have you changed your OEM MAP sensor for a 4 BAR one?In all honest I doubt my car is making 340bhp but just going by what happened last time, 219g/s scaled it made 317bhp @ 1.5 BAR, it's now making 236g/s (scaled is 273g/s), since last dyno run it has JBS manifold, ported head, Fluidampr crank pulley, big Forge FMIC instead of cheap ebay one and 1.7 BAR of boost.
this is a new one on me, why not just fit a larger capacity MAP?No, I have 'clamped' it so I can run whatever boost I want without getting limp mode. Clamping is fitting a 4.7v diode to the MAP sensor wiring to fool the ECU into thinking you're not going above 17psi..
