Revo Stage 2 K03s Logs
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
All you'll get is this
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
what 031 log do then?
still waiting to get mine all sorted then ill be getting some logs up see what can turn mine uptio :)
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Looking at this, How bad actully is it? and what can be done to make it better?
Please bear in mind that actual and requsted are the wrong way round in this graph.
Also off topic slightly, After fitting my jetex open cone and im seeing 174 g/s and i was getting 172g/s with my modded box. Is there anything that can be done to improve this? Or is it just a case that the turbo cant shift anymore air?
Cheers.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
I found cranking my wastegate out dropped my wastegate duty at higher RPM. But i assume you have already done that? I was hitting 99`s for a few stamps high up.
-pseudonymous-
681
Heres a log of mine from a month or so ago Daz. As B3nny said the waste gate duty dropped a fair bit towards redline after cranking the actuator a bit.
B3nny MAF readings in the mid 170's is fine, ive only seen mid 180's in really cool weather conditions right near the rev limiter.
Code:
Group A:	'114				Group B:	'115				Group C:	 Not Running
	Load	Load	Load	Load		RPM	Load	Absolute Pres.	Absolute Pres.
TIME					TIME					TIME
STAMP	%	%	%	%	STAMP	 /min	%	 mbar	 mbar	STAMP
0.29	174.4	167.2	116.5	100	0.59	2400	130.8	2150	1640
0.89	180.5	174.6	142.9	100	1.19	2640	153.4	2180	1970
1.49	183.5	177.6	163.9	87.8	1.79	2880	176.7	2190	2270
2.09	186.5	179.1	190.2	84.7	2.39	3200	191.7	2180	2500
2.69	188.7	182.1	191.7	82.7	2.99	3520	191.7	2160	2500
3.29	190.2	183.6	191.7	81.6	3.6	3800	191.7	2150	2490
3.9	190.2	183.6	191.7	80	4.19	4160	191.7	2140	2460
4.5	190.2	183.6	191	76.1	4.8	4600	188	2120	2290
5.09	190.2	183.6	188	73.3	5.4	5080	181.2	2120	2220
5.7	186.5	179.1	176.7	70.2	6	5280	169.9	2080	2140
6.3	184.2	177.6	169.9	69.4	6.6	5320	166.9	2090	2110
6.9	180.5	173.1	166.9	68.2	7.2	5240	167.7	2090	2100
7.5	182	174.6	167.7	68.2	7.8	5400	162.4	2080	2090
8.1	174.4	167.2	160.2	66.3	8.4	5640	157.9	2030	2060
8.7	173.7	165.7	156.4	65.5	9	5800	154.9	2010	2010
9.3	171.4	164.2	155.6	65.1	9.6	5920	153.4	1990	1970
9.9	167.7	159.7	151.9	64.7	10.2	6080	150.4	1970	1960
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Cheers, I worry to much...:redface:. Just want the car running as good as it can. But its pretty hard as my knowledge of this kind of thing is very limited, but hey im trying ;)
I managed to drop my wastegate duty from around 97% IIRC to around 80% had to crank it out a fair bit though. Im thinking of doing it again this weekend, would this help hold boost better?
May 25, 2004
2,691
Newport, South Wales
222 @ westec way back when. Martyn has his black Cupra R then, he ran it with same mods plus ATP mani and achieved 226.
Both of us saw a strange dip in the power curve on that occasion. Would of seen 230+ easily I would of thought. Got a graph somewhere i'll try find it.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
that was running k03s? Westec have destek rollers dont they? Im running on a set of these in january. Hoping for better results than my 197bhp from september :censored:
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
yeh it will, as were all pretty much running the same spec and getting simlar logs... results arent the be all and end all but its still nice when it pulls a nice figure in front of a crowd ;)
powerstation running destek rollers?
