Rev climb and noise
Apr 17, 2020
Mk2 cupra Leon CDL engine code
Today I experience the car when in neutral the revs climbed with out me doing anything then started making a weird noise. After a quick look under the bonnet with air filter off it seemed it was coming from PCV area when I pressed the round part of the PCV, engine tried to cut out then idled normally until revved then let isle as normal then done the same thing.
Legojon
I only wanted a remap
5,309
2,739
PCV on the CDL engine is held on with 4-6 tiny screws and just pulls off. 5 min job to replace. But you could take it off and have a look inside. Generally, there will be some oil residue. but if it's covered then it's gone.
Reactions: Cupraalex
Apr 17, 2020
Thanks for your help. I’ve cleaned and ran it for a bit everything seems fine now so if it happens again I’ll replace or delete I think
Reactions: Leeoncupra
