I'll give my dealer a call and see what this letter is about. Its dated the start of December so it can't be that much of a risk!
BMcN said:I'll give my dealer a call and see what this letter is about. Its dated the start of December so it can't be that much of a risk!![]()
BMcN said:Well the pipe in question (in that picture) is not really enough to cause anything dangerous to happen. It will just start to draw air in and cause the brakes to feel very hard - at which time you should stop. Guess it may not be too handy if your on the motorway.
. Maybe the lighter Beezer would be slightly better, but the Leon required major leg effort to bring it to a halt. I got a real fright, and there is no way my wife would have been able to press hard enough to trigger the ABS ...... mik said:Brakes don't go hard ~ you lose the servo assistance so you're directly connected.
I wouldn't have thought this would be the end of the world either as I've driven several cars with no servo assistance. No servo and failed servo are different things however.
I can confirm that it's not good at all. Maybe the lighter Beezer would be slightly better, but the Leon required major leg effort to bring it to a halt. I got a real fright, and there is no way my wife would have been able to press hard enough to trigger the ABS ......
If you're taking your car in anyway you can cut yours on the way in and see for yourself.![]()
nudesign said:turn you engine off and ignition, roll down a hill and try to brake. see how hard it is?
cupra_matt said:Just to clarify things. The servo pipe will not be replaced on any of your cars, only repaired if it is cracked, if its not cracked then it is unlikely to crack in the future. I know this because iam a seat technician. Checked mine today and its fine.
mark sheerin said:As for losing the servo leaving you with 'normal' unservoed braking...this is nonsense..
The brake system will be designed to work with BOTH together..if it wasn't going to be servoed in the first place then a different master cylinder would have been used from scratch to get managable braking effort.
