Rear shocks knocking
Drewbot
7
It was passenger side rear in my 184 too. That is the side that hits all the potholes at the edge of the road I guess. I'm glad the Northampton dealer was happy to replace the dampers and top mounts on both sides to be sure. I guess it's a labour cost vs part cost thing, and to keep you happy so you come back to them for servicing.
chrispcupre
767
9
leicestershire
i have the same noise 33k miles on my 5f leon fr tdi n/s/r knocking on shallow bumps etc ive only had the car 10 months as i bought it used i am ordering the rear shock top mounts and after market shocks proberly monroe oe spec and see how that goes
Mar 23, 2020
Hi guys, i have hunting the same sound for 4 years now. Did you guys ever find the source of the knocking noise?
Norbert
395
98
Rear socks rubbish in fr.i fitted bilstein after 18moths and huge different.comfort better and no banging,hold better weight.vw know the factory fitted socks rubbish and replace under warranty the same rubbish.
Kinetic
118
35
I had a knocking noise from the rear on the driver side. Turned out to be some play in the locking mechanism for the rear seat. I fixed it with a bit of insulating tape wrapped round the locator on the seat to make it a tighter fit.
SeanD
10
I was waiting for someone to mention the rear seat knocking noise. I've had two FR184's and both had this issue, releasing the seat and giving it a hard push back into place was the initial cure. Like yourself I ended up putting some electrical tape around the bar which did the trick.
Reactions: Jay5959
Jay5959
FR 184
Apr 26, 2020
502
259
I’ve got a lovely creaking sound on my 184 going over rough roads and speed bumps. No knocking, so not arsed atm. Last service noticed some light misting on one of the rear shocks, very common for age and model apparently. Probably just change out the bushings (maybe go poly) and springs when the shocks need changing. See if that makes any difference, but after reading this thread and related threads I doubt it 😂.
SuperV8
1,812
891
Creaking is probably a rubber bush somewhere, or could be an anti-roll bar drop link. I would avoid any poly bushes on a road car.
Light misting is 'acceptable' according to VAG!
Unless your car is sagging or the springs are very rusty or you want to change the ride height I wouldn't bother with new springs.
Reactions: Jay5959
Jay5959
FR 184
Apr 26, 2020
502
259
Good points mate, I was more thinking of maintaining it well for years to come. Need to keep this car going for as long as possible. Shocks and bushings when needed it is 👍
