Radiator Top Hose/Radiator?
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
Im sure when I put mine on it found the centre of that rubber itself. The screw just goes down and the bottom of it goes into the groove and holds it in place.
so the bolt went on the top of the panel that has the bonnet lock on?
so on this pic, is it the panel just above the grill?
sorry for dumb questions, i just don't know how it should look like!
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
See the passenger head light, above it on the panel there is a bolt. It is inline with the edge of the battery. In the small section that is lower than the rest of it. Thats on the the bolts. There is one on the other side to. If you can get your head in and see the mounts on the radiator you can follow the screws up.
Im sure its an 8/10mm socket for them.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
top of the front slam panel (black) the rad mount bolts are always the rusty looking ones facing up vertical
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
thanks to both of you, i will be having a crack on saturday morning, as i haven't had time (uni) and need the car tues!
just wanna know how to do it, as it's doing my head in, sick of it!
much appreciated!
also i might have a new slam panel (as one of the legs that hold the rad on mine is kinda broke) but the person doesn't know if it's from a AC/Non-AC ABF? does it matter?
so i can sort this problem once and for all!
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
thanks alot flapper, i thought you was on about them 2 :D i ge tthe jist
any idea's on slam panels ^^^??
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
slam panels listed different for AC but i cant remember why as the condenser is screwed to the rad itself
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
yeah that's what i thought initially mate! hopefully it will fit! gonna have a crack tues!
so i need to take off bumper/lights to take it off (first time taking it off :p) lol
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ye but its pretty much an easy job to be honest
indicators out so you can get at grille fittings
grille off so you can get at bumper
bumper off so you can get at lamps + panel nuts/bolts
unscrew headlamps
2 bolts in each top corner
2 nuts on each chassis leg iirc
apart from bonnet catch (unclips from block halfway along it )be easier to swap with panel on floor
give or take thats pretty much it
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
thanks so much flapper, i thought it'd be exactly like that, just wasn't sure there was any more nasty's to take off :D
hopefully will be able to tell you guys if there is a difference between a AC/Non-AC slam panel!
