Since I start doing B5 V8 swaps back in 2008, I have had a lot of enquiries, mostly regarding converting the C5 RS6 to manual.
As many may know, the C5 RS6 block is unique to it’s application to automatic transmission. It runs a much larger torque converter than regular V8 engines, similar to that fitted to the W12 engines.
This means a larger diameter flexi plate, and a larger rear mounting surface to bolt to the larger RS6-specific automatic transmission bellhousing. The RS6 block will bolt to a regular 01E 6-speed manual, but some machining, drilling and tapping is required, to ensure all bolt holes are used. Without this, only 4 bolt holes line up.
I encountered this issue with my last swap, a BFM 4.2 V8 40V from a 2005 D3 A8 into a 2000 B5 A4 2.8 Quattro, married to an 01E. A days worth of measuring, marking, machining, drilling and tapping got all 10 bolt holes used.
So, I will split the 077-series 40V blocks into 2 groups:
SMALL BLOCK.
D2 A8 3.7 / 4.2 V8, 1999 - 2002.
D2 S8, 1999 - 2002.
C5 A6 4.2 V8, 1998 - 2003.
C5 S6, 1999 - 2003.
BIG BLOCK.
D3 A8 3.7 / 4.2 V8, 2003 - 2005.
C5 RS6, 2002 - 2004.
Identification of the blocks are simple:
The starter motor aperture on the “small blocks” forms a continuous hoop.
The starter motor aperture on the “big blocks” forms a split hoop (like a “C”).
SMALL BLOCK.
BIG BLOCK.
SMALL BLOCK.
D2 S8, 1999 - 2002.
C5 S6, 1999 - 2003.
BIG BLOCK.
SMALL BLOCK.
BIG BLOCK.
