"Positive values indicate that the engine is running too lean and oxygen sensor control is therefore making it richer by increasing the amount of time that the injectors are open."His trims are positive, and the lambda says its running rich.
http://www.ross-tech.com/vag-com/cars/fuel-trim.html
With lamda readings, the higher the reading the leaner the mix and consequently the lower the reading the richer the mix. ie 0.78 is richer than 0.85 as an example.
