Re the injectors ... my bad, i thought you'd physically uprated them rather than stating thier true flow inconjunction with the 4 bar reg.
To be fair and i should have stated this i only fed the dynatwist from the stock wing feed position, due to being paranoid about water ingress from the fogs position.
Try a large jetex cone guys, not the ultimate solution but should raise your g/sec.
If the diablis wasn't so expensive i'd have a bash at moding a 2.0tfsi one to fit the lcr. it takes high air velocity without bends staight into the intake without any water issues.
The more air that can be fed into the turbo the less work it has to do.
i had good gains with a cutom 3 inch tip that i used to recommend whole heartly but others haven't achieved the same gains.![]()
No worries
ill keep an eye on how you get on. just so you know, the figures ranked in this order in terms of CIA placement
1st - twin CIA
2nd - 1 CIA (fog)
3rd - no CIA
4th - CIA to behind headlight (stock)
ill be changing my induction side very shortly when i go BT so i should really start thinking about how im going to do it.
Might be tho aaron? your airflow is great, but what if you can get better im looking at this
Alltho Wooki said he seen better flow with one get got from flee bay.
ill keep an eye on your thread too hehe...
