Won a
Mk2 Leon FR gear knob on 'the Bay' so decided to fit it this morning.
Here's how I went about it (just in case anyone wants to do the same!):
Remove old gear knob gaiter assembly by pushing forward on the back of the gaiter base then lifting it up. Pull the gaiter over the gear knob & cut off the metal clip - this is a one use only clip.
Pull the gear knob off the gear stick and remove to a more comfy location
Pull gear knob inside out to reveal a plastic retaining clip, unclip this and pull out old gear knob.
Push new gear knob through gaiter, I secured it to the gaiter with a tie-wrap due to an angle on the base of the gear knob which would not allow the plastic retaining clip to fit.
Push the gear knob/gaiter onto the gears stick making sure it's lined up, I secured it with a small jubilee clip.
Push the gaiter base front into location (2 lugs fit into 2 slots) then press the back down into place.
Job done
