On the map side of things. I originally had a map for the gt2860 with 550's at 3 bar with an inline pump. The newer map was for the gt2871 with the 630's at 3 bar with 3 bar map sensor and s4 maf. I have the map on an ecu if you want to try it or you could even buy the ecu with the map on it?
3bar map sensor a differnt part then? And S4 housing with
Ibiza element?
Im still waiting on Kev to get back to me and Craig @ GotBoost (Revo dealer and a friend) about the map, but as im still building it im in no rush.
Im actually just thinking about using the standard Stage 3 map on a S3 MAF and 550's as ill be running the setup off the WG spring (0.9bar) until i do the head work, at that time ill probably change the map.
Im still not sure whether or not there is a restrictor on the oil feed for this turbo as well, something i need to check, and if not ill make one here in work i think.
Managed to paint my inlet last night successfully using the VHT wrinkle paint to match the rocker cover, looks awesome fair play. Gonna paint the power steering cap in it as well as a few other things i reckon.
Ill take pics of everything tonight.
