Peter's Leon - *Mapped* *Soon to be Stealth*
Petey41
182
Northern Ireland
It's the module witch control your central locking, windows and some other things.
Windows work fine as well as the central locking inside the car, just no remote locking. I do remember that before sometimes you would have to push the button on the remote several times before it worked
Sent from my HTC One using Tapatalk
J.B.
175
Holland
That's good. If i do that only the driver side unlock. I think in your case it's just the key.
Petey41
182
Northern Ireland
That's a bit less of a worry, thanks for your help man! Would you have any idea how hard it is to reprogram? I only have the one key at the minute..
J.B.
175
Holland
If you have Vag Com or VCDS its not that hard. But i can't find the instructions right now. I thought there was one option to do it without vcds.
J.B.
175
Holland
This is translated from dutch. Maybe it can help.
1. It is necessary that both be used in the car keys supplied, both the key with remote transmitter (A) when the normal key (B) is used.
2. For synchronizing one has a maximum 30 seconds.
3. Key (B) is used to turn the ignition key and (A) is the key to be programmed.
4. Make sure the car is unlocked before starting. Programming
5. Turn the key (B) in the contact position between the positions of the steering wheel and start.
6. Connect with key (A) the end of the driver's door of the wagon.
7. Unlock and then lock the lock of the driver's door with the key (A) while holding down the button (Unlock 1) of the corresponding key is pressed.
8. Take finally the key (B) from the ignition.
Petey41
182
Northern Ireland
Awh not too bad! I have vagcom so I'll get a key and give it a go, cheers mate! :)
Petey41
182
Northern Ireland
Cheers dude, your a legend!
