There is loads of choice!do you want some that bolt straight on?
Sent from my GT-I9195 using Tapatalk
Ideally man, 5x100 would be sweet!
Sent from my HTC One using Tapatalk
Battery??
Hopefully its not your comfort module....
It's the module witch control your central locking, windows and some other things.
So when you unlock the car with the key (not the remote) all the doors unlock?
That's good. If i do that only the driver side unlock. I think in your case it's just the key.
If you have Vag Com or VCDS its not that hard. But i can't find the instructions right now. I thought there was one option to do it without vcds.
This is translated from dutch. Maybe it can help.
1. It is necessary that both be used in the car keys supplied, both the key with remote transmitter (A) when the normal key (B) is used.
2. For synchronizing one has a maximum 30 seconds.
3. Key (B) is used to turn the ignition key and (A) is the key to be programmed.
4. Make sure the car is unlocked before starting. Programming
5. Turn the key (B) in the contact position between the positions of the steering wheel and start.
6. Connect with key (A) the end of the driver's door of the wagon.
7. Unlock and then lock the lock of the driver's door with the key (A) while holding down the button (Unlock 1) of the corresponding key is pressed.
8. Take finally the key (B) from the ignition.
