overheating
davenlucy
hi all.ive got p reg beezer with a 1.4 engine in and its decided to start overheating.just my luck as i planned to sell it:( i replaced the thermosat as i thought this was the cause and when i filled the expansion tank up with water again it burst at the seam when it got hot and started leaking.now the temp gauge rises really quickly and i end up with losing all the water out the expansion tank and lots of steam out the bonnet.could this be caused by a air lock in the system somewhere? or the head gasket? any advice or ideas would be greatly apriciated.:)
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
it's likely that there's either an air lock... or the thermostat is still duff
remove it :) and pump the air round by squeezing the top pipe (when it's cold unless you like burns)
davenlucy
cheers for the replys.ive removed the thermosat and bleed the water pipes loads of times and its still doing the same thing.ive removed each pipe one by one and ran a hose pipe down each one to make sure they wernt crudded up and it aint made any difference although alot of bubbles came out of the expansion tank.the temp gauge reaches the max mark n im getting a banging noise n the pipes move round due to the banging.as for the gasket theres no oil in the water n vice versa.
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
so all other water pumps dont ever fail because it isnt on a 20vt?
doesnt mean that the water pump cant die....my brothers on his ford died last week and he has exactly the same symptoms. The bearings in it were buggered
davenlucy
on a guess im guessing the water pump as i spent 3 and a half hour bleeding the damn thing n its still doing it so im riping the engine apart to fit a new one.the blades on the new pump are metal not plastic too. thank you for all your replys .@)
davenlucy
righty just a quick update on my progress with my beezer.it was the water pump that had gone due to the bearings and the complete fan was just spinning on the drive shaft.once again thanks for the ideas. :mad:)
