Oil light keeps coming on
Prau187
204
95
I'm jus getting the turbo checked tmrw
mty12345
4,107
680
bristol
Turbos gone had it checked out
Ouch soz to hear that mate. Thats the trouble with turbos, the RPM's are so high that they only need to spin up once with low/no oil pressure and thats enough to kill them.
Prau187
204
95
Yep at least it's not the engine but I have sent the turbo of to get it reconditioned hopefully the car will be out by today
Prau187
204
95
Cars running good now after the turbo has been fixed
Prau187
204
95
Jus got one problem tho when the car has warmed up and the idle needle is at 90 it's start to go back down to 60 when I start to throttle the car but when it's stationary the heat needle goes bck to 90
mty12345
4,107
680
bristol
Glad to hear that it's ok now mate, the symptoms you describe are classic thermostat, they fail all the time on these engines. Luckily they usually they fail open like yours has so the car underheats rather than overheating.
Prau187
204
95
Thermostat, do I need to replace that or has the engine gone because it's quite annoying when I'm driving on the motorway and I have to pull up in the service station all the time
mty12345
4,107
680
bristol
Yeah you just replace it mate, bout £10 easy enough to do if a bit fiddly. It bolts to the engine block where the coolant hose goes in to the block. It's kind of behind and to the right of the alternator. 2 allen key bolts.
Prau187
204
95
Cheers pal will get that done straight away
Prau187
204
95
Hey pal the same problem has accured with my seat I've not drove my car for 30 days it was parked up so I decided to drive it today after abt 2 hrs later the oil light has come on again that's only when I fully throttle the car
Prau187
204
95
I had to park the car up and let it settle to a low temp b4 driving back home
Prau187
204
95
The oil light keeps goin on and off I've jus had the oil pick up pipe cleaned abt 2 months ago it's weird
mty12345
4,107
680
bristol
Hi buddy, sorry to hear about your issues. If the pick up is new, then either you have a fault with the oil pressure switch/wiring or you have a problem with the oil pump or worn bearings.
I would change the oil pressure switch and then go from there. I'm pretty sure it's next to the oil filter from memory.
If the light is still coming on when the switch is replaced and the wiring checked, then you need to get the oil pressure checked to see if it's low.
Prau187
204
95
Hey Pal the oil light has jus gone off I've been driving mellow and it seems like it's ok I've not throttle the car yt
