neil_f225 said:cooler wouldnt go at front of bumper as the fittings for the oil hoses fouled the crash bar when the bumper was refitted. Have now mounted it vertically against the radiator. Hopefully fit the sandwich plate over the weekend and then see what difference it makes.
neil_f225 said:yeah plate screws onto block where filter attaches at present and then the filter screws onto the sandwich plate. I think i ordered about 4m of hose which was plenty. You need to use plenty of ptfe tape on the threads for the fittings that screw into the sandwich plate or else it will leak when oil is warm as i found out
neil_f225 said:yeah filter stays in normal position though does get close to lower intercooler pipe. Just unscrew filter, screw on sandwich plate and then filter back onto plate. Easy as that. If you have a fmic it will give more room as you wont have the lower intercooler pipe.
neil_f225 said:you are probably best doing an oil and filter change at the same time as some oil will leak when the filter is removed.
neil_f225 said:thermostat is built into the adaptor and allows the oil to warm up quicker. When oil is above 80C it will open allowing the oil to flow through the cooler ( just like the thermostat in a radiator). Without out the oil might not reach proper temp or would take ages
