obtaining replacement code for RNS-510
Jun 5, 2008
511
Leeds
do anyone know if/how you can obtain the code for an RNS-510 unit. I have emailed seat today who said to speak to my local dealer, I did and they said they did not know of the unit I was refering to (jct600 Rawdon are rubbish) anyone know if it's possible?
Jun 5, 2008
511
Leeds
no it didnt, its a flee bay purchase, i was hoping that i would be able to obtain the key code from the dealers, or maybe contact siemens but its looking pretty dimm
Jun 5, 2008
511
Leeds
had a look and spoke to some of the guys on there and i think that it may be fruitless task.... i shall continue in my efforts!!
ianrob16
Spenny2004 is it a Seat version RNS510 ?
If so just wire up the SAFE pin at the back of the unit on the main multi plug to a constant 12 volt source. This advice was on the main MFD3 threads on the Leon Mk2 forum. Ian.
Jun 5, 2008
511
Leeds
Yes it is a seat one. thanks for the reply so what happens if I do this does it disable the keycode and does it cause any damage to the unit at all? Could you post a link to the thread you got this info from.
blocky
Hi
i did the safe pin thin g and to be honest it sometimes does ask me for the code.. i just reset the unit and its good to go for another few months.
How do you reset the unit,
As last night mine asked me for a code, I made two journeys, then this morning it worked as normal.
Without touching anything.
flakmunky
Olympic Knitting Champion
Aug 23, 2005
652
Marmitehampton
The Safe connection DOES NOT disable Key Code request. It is a constant 12v feed and it is required for the alarm / memory. Without the Safe connection the unit shouldn't take the Key Code, when you enter the code it should tell you "safe pin not connected".
My car needed a safe pin fitting which was fairly easy. Once fitted correctly you will never have to enter the Key Code again. The car also needs programming via VAG-COM.
My Golf MkV had the Safe connection, the Leon didn't. I just dug a female connector out of an old ISO connector I had lying around and used a ScothBlock to tap in to a permanent 12v+ on the Quadlok connector.
Regards,
fM
ianrob16
To reset the unit press the two buttons (left and right direction arrows) to the left of the CD/DVD slot and the extreme right hand button (voice symbol) simultaneously and the unit should shut down, I them wait a few seconds and turn it on again with the rotory ON button.
Maybe I too an due a code request but with the safe pin powered it certainly has not happened since I fitted the unit in early August. Ian.
blocky
where can I locate a key code, is this printed on the unit anywhere ? or is this in the satnav manual that would have come with the unit?
Dec 15, 2007
1,143
South East London
dave if yours didnt come with a code how did you get it to work if you dont mine me asking??
I just plugged it in m8, was told it wouldnt need a code and it didnt.... it had already been updated and new maps added etc.... I didnt mess about with any wiring apart from swapping 2 wires for the iPod and it occasionally asks me for a code but doesn't follow any logic, ie after 2 weeks away it started up fine, but on a short trip to Sainsburys yesterday asked me for the code!!! I just reset it and its fine after 20 seconds or so...
