Deleted member 103408
Well assuming its a Genuine Ross Tech cable and that its the right version for your car that is one issue out of the way.
What coding were you using to make the changes
For the FIS The coding I have is
Put FIS carbon background
With this mod, we change the background FIS Carbon mode.
1 - Module 17 - Code Box instruments- (25327)
2 - Adaptation
3 - Select Display Image
4 - Select one of the options:
- Option 1 (default)
- Option 2 (Carbon)
For the Infotainment its
Activated carbon background Infotainment
With this mod, change the background screen infotainment to Carbon mode.
1 - Module 5F - Electronic Information 1. Code (20103)
2 - Extended Code (Text mode)
3 - Byte 17 Skinning
4 - Select Skin 3
But this is pre facelift, not sure if its the same on Facelift.
2 - Adaptation
- Option 2 (Carbon)
4 - Select Skin 3
