So I tried the below instructions (taken straight from
OBDeleven forum) to enable door lights flashing between white and red when the indicator is turned on.
Ambient door light with flashing and color change
With this mod, bringing the doors in red, when flashing, the door on the side of the indicator flashes between red and white.
1 - Module 09 - Electronic control unit. Code (31347)
2 - Adaptation
3 - Select - Leuchte16BLK SLB35BLK SL KC9
4 - Submenu - Lichtfunktion C
5 - Change value to Blinken links (beide Phasen) BOTH SIDES OF INTERMITTENT or Blinken links (Hellphase) ONLY WITH INTERMITTENT LEFT
6 - Select - Leuchte16BLK SLB35BLK SL KC9
7 - Submenu - Dimmwert CD
8 - Change value to 0
9 - Select - Leuchte16BLK SLB35BLK SL KC9
10 - Submenu - Dimming direction CD
11 - Change value to Minimize
12 - Select - Leuchte16BLK SLB35BLK SL KC9
13 - Submenu - Lichtfunktion E
14 - Change value to Blinken rechts (beide Phasen) BOTH SIDES OF FLASHLIGHTS or Blinken rechts (Hellphase) ONLY WITH RIGHT INTERMITTENT
15 - Select - Leuchte16BLK SLB35BLK SL KC9
16 - Submenu - Dimmwert EF
17 - Change value to 0
18 - Select - Leuchte16BLK SLB35BLK SL KC9
19 - Submenu - Dimming direction EF
20 - Change value to Minimize
21 - Select - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
22 - Submenu - Lichtfunktion A
23 - Change value to Blinken links Hellphase
24 - Select - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
25 - Submenu - Lichtfunktion B
26 - Change value to Blinken rechts Hellphase
This seems to have disabled the red lights when in sport mode, and the lights only flash between white and off.
Is it possible that I've blown just the red LED's or am i missing something else?
Having a lot of trouble with this one. I'm currently in the below position.
In Normal mode the white LED is not turned on. When the indicator is turned on, BOTH left and right doors flash between white and off.
In Sport mode, the red LED is always on as normal. When the indicator is turned on, BOTH left and right doors flash between red and white.
I've diagnosed the no white LED to the following steps
Lichtfunktion A needs to be set to Ambientelicht 3 to retain white light, but no lights flash no matter what mode I am in with indicator on. I assume with this mod I have to sacrifice the white LED's always on.
What I am really struggling with is to get ONLY the corresponding door light to flash with the direction of the indicator. Does anyone have any further information on this mod?
