OBD11 For the Tarraco
  • Thread starter Deleted member 103408
  • Start date
t_v
101
78
Is that something they left out 🙄. That's Seat rushing out the Tarraco then.
I like the way they messed up the WiFi on the 2016 model which meant their subsequent apps didn't work with it. Lacking on QA in the first release.
I don't think so, the settings described in your video are all there, do you have a screenshot of the extra Ateca settings?
t_v
101
78
Expressed another way, what do you think you are missing off the Tarraco.
I don't think we are missing anything on the wiper front currently after the latest submission, you mentioned that there are extra settings on the Ateca for the rear wiper so I am trying to figure out what it is as I can't see it in the OBD.
Specifically, one that allows granular control of the rear wiper where it can be controlled separately when raining rather than follow the same setting as the fronts.
Tell
No just an automatic wipe if raining when you put it in reverse. I don't think it does anything else fancy.
t_v
101
78
Added Enable "rear window wiping in reverse gear" control under "Mirror and wiper setup".
Reactions: Tell
t_v
101
78
TSR for a FR 2022 was tested with correct names of adaptations etc now reflected in the first post (under Traffic Sign Recognition Activation 2021 on), however, the setting "Road sign detection fusion mode" is not available for editing even though it appears correctly in the Adaptations list. This results in a TSR error and the system doesn't work.
Anyone who has managed to overcome this without (as I suspect) the need for VCP kindly share.
Tell
They have closed that mod down now post FL models. Some is due if not all to the camera spec. Prior to the FL models some didn't have the extended spec to enable it seemed to be more on non Seat models. Probably as they started to close the mod down to be factory fitted only.
Ivan Ryban
39
Has anyone tried the ECS deactivation app via OBD11? I would love to activate it, but I am still gathering courage, because I would like to avoid doing damage to the car software.. When I last used the seatbelt warning deactivation app I ended up having to replace the abs computer in the car, which would not be a cheap issue having to fix it myself (luckily it got replaced within warranty conditions).. Thank for sharing your experience
Jimbobcook
6,169
2,551
Great thread here! Shame about new Tarraco's not being able to enable all of the Traffic Sign Recognition coding.
Looking at the high beam assist and a few other bits like remembering last used start stop option etc hope the fact my car is pretty new that things aren't locked out.
Reactions: Tell
Tell
Think that's the camera being more limited in them unless the thread said different.... The last setting of lane assist is where the Leon 4 / Formentor (MQB Evo) varies from the one here as I was dishing out the solution here to them... It's another key word setting. Think you neutralise stop start the normal way with the Tarraco, voltage method. MQB Evo you cant. Still all EV soon 😉.
cairus
1,260
454
Control Unit 5F (Multimedia)
using 'Adaptation'
"Function Configuration Connectivity"
"WIFI Hotspot 5GHz" to 'On' (was 'Off')
"App Connect over WiFi" to 'Yes' (was 'No')
"Mirror Link" to 'On' (was 'USB only')
"Apple Car Play" to 'On' (was 'USB only')
changed.
Soft reset mib
No Warranty
Reactions: karkoura
Tell
H57 in this thread with privisos
Jul 29, 2021
36
cairus
1,260
454
The integrated navigation system has nothing to do with SmartLink/Full Link. ODIS is required in the workshop if SmartLink is purchased afterward. However, Wireless SmartLink doesn't require ODIS, only a good diagnostic system.
Reactions: karkoura
