OBD Modifications
Tell
Hi,
you advise me to buy ODB11 or VCDS ?
It is an Obdeleven thread 🤔. VCDS costs a small fortune whilst Obdeleven Pro doesn't. There are dubious knock offs of the VCDS plug which aren't licenced apparently. VCDS has it's fans.
Background reading:
Quick read I reckon that £79 box just reads the codes doesn't program for that on VCDS you need those big figure devices whilst Obdeleven Pro does everything 😉.
True VCDS costs are in this text from that article
These are the products in the Professional Class:
  1. VCDS® Premium Professional Kit: costs $1,299
  2. VCDS® Professional Kit: costs $899
  3. VCDS® & VCDS-Mobile® with HEX-NET® Professional – WiFi & USB Interface: costs $599
These are the two products in the Enthusiasts Class:
  1. VCDS® & VCDS-Mobile® with HEX-NET® Enthusiast – WiFi & USB Interface: costs $449 (10 VINs)
  2. VCDS® HEX-V2® Enthusiast – USB Interface: costs $199 (3 VINs) – $299 (10 VINs)
There are VCDS people on the board round here whether they have Chinese clones pass. They would know. The chatter about cables you read.
Reactions: klez
Dec 7, 2022
Does anyone know of a way to code the front drls? I can't find which "Leuchte" they are, I've played around with every single one and none seem to be it, are we unable to code these? (it isn't the sfd lock, I unlocked that for 90 minutes during coding)
Feb 22, 2022
97
47
dal momento in cui ho sbloccato sfd, mi da errore perenne allo 09 in cui dice "ATTIVITA' ATTIVA" ma credo sia normale, credo sia la traccia che rimane dopo aver sbloccato sfd; Sapete se c'è un modo per rimuoverlo?
RoadXY
75
21
The Netherlands
Google translate:
from the moment I unlocked sfd, it gives me a perennial error at 09 in which it says "ACTIVE ACTIVITY" but I think it's normal, I think it's the trace that remains after unlocking sfd; Do you know if there is a way to remove it?
Dec 7, 2022
Does anyone know the number for the front DRLs at all? I’d like to change some code with them but I can’t seem to find the “Leuchte” number that they are, thanks
Jan 9, 2023
Hi, i have an Cupra Leon ST - E-Hybrid with the L-Paket.
My Cupra is Mj23, i just got it in december 22.
How can i check (i have VCDS) if my stearingwheel does has capacitive function?
Widil
108
22
L-pack means your wheel is not capacitive.
anyway, just try the coding for travel assist, you can find it in this thread, and find out for yourself
KokDu
43
12
Here you can find a picture of a capacitive steering wheel. Check the button with the lanes (underneath the Res button).
Nagrom
7
Hi, I'm planning on buying a capacitive wheel for my Cupra Leon to add Travel Assist (I currently have the Pack assist L).
However, I was wondering if I could put a Supersport wheel and have the two additional buttons working ? As well as the central button remapped from Start to ESP ?
I guess it's not that easy as plug and play but if someone here has some knowledge about it ?
alias76
30
Hi all, I'm wondering if it's possible and some of you have already done this coding
My Ateca is a FR 2.0 TDI 150 HP year 2022
thank you
Control unit: A5 Driver Assistance
System description: MQB MFK 3.0
Software number: 2Q0980653D
Software version: 1401
Hardware number: 2Q0980653
Hardware Version: H16
these are the values in mine in A5 in attacchment
alias76
30
and this in central 13
Backups
Control unit: 13 Adaptive Cruise Control
System Description: ACCCONTIMQB
Software number: 2Q0907572AA
Software version: 0396
Hardware number: 2Q0907572D
Hardware Version: H09
alias76
30
Hi guys,
- Hupen durch Fahrerassistenz
- Set to Active
- Travel Assist
- Set to Active
- Innenlicht durch_Fahrerassistenz
- Set to Active
Alternative
- Select Adaptation
- Interior light general setting
- Set to active
hello I can not find these items in 09
ateca fr 2022
thank you
