NEW ibiza Cupra - speed blue!
nightflight
2,677
12
Sheffield
@CGD217: AIUI the IAM course basically covers the "Roadcraft" manual/system of car control,
it's about £100-140 to join a local IAM group (google for details) who then send you out with a local assessor/trainer for driving lessons based on Roadcraft, once you're at a good enough level you have an assessed drive (test) which if you pass gives you full IAM membership.
The other option is RoSPA, which uses the same book as its basis, but requires regular re-tests to maintain membership (not expensive as i recall) and has bronze silver and gold pass levels.
Neither had any effect on my insurance quotes when I tried them on confused.com but I'll still be doing probbaly RoSPA when I can afford it/place available on a course just to improve my driving smoothness and safety
NathWraith
Misfiring like a boss
Sep 2, 2011
402
Staffordshire
Any answer to the above? I may have missed it
Nightflight got it in one :)
NathWraith
Sep 2, 2011
402
Staffordshire
Picked her up today during lunch break. VERY impressed, taking it easy and filled her up full with V power :)
Gonna take her for a drive tonight, to test out those xenons!
Nutkin
Pop-a-Keg ya?
Aug 24, 2006
2,581
Schnaitsee
Run it in gentley for 1000 miles without using cruise control, I don't care what others say but I've seen enough tests at work with long running tests to see the better fuel economy from the properly and gentley run in cars vs the limit handeling ones that are thrashed from birth.
NathWraith
Sep 2, 2011
402
Staffordshire
How come no cruise control? I haven't used it yet but just wondered why.
Did 100 miles last night, taking it easy. Fuel counter only went down by 1 bar (1/8 tank) :D
Mr_Dave
lnk cr b82rez 2g4!
Aug 8, 2007
1,302
Cheshire
:shrug: I don't see an issue with cruise. I used it.
Fuel counter will go steady til half, then it'll drop from half way to nothing after 100 miles :lol:
Nutkin
Pop-a-Keg ya?
Aug 24, 2006
2,581
Schnaitsee
You will want to be varying the engine conditions and speeds to bed in the piston rings properly to vary the engine speed during wear in so that the top/bottom ridge (at the top and bottom of the cylinder bore) of the piston stroke is tapered.
Its not that the cruise control is bad its just holding a new engine at a constant speed can develop a sharp ridge which wont help the top piston right on top stroke or the oil control ring on the bottom of the stroke.
Idealy every now and then give the paddle a flick and drop a gear.
For abour 5-600 miles keep it easy and then start going up about 1000rpm every 100 miles after.
End of the day you can do whatever you want it is your car, but a properly bedded engine can make a huge difference in MPG and Oil consumption.
NathWraith
Sep 2, 2011
402
Staffordshire
Ah I see.
I have been using the gears tbh, I thought it was best to use a range of RPMs but nothing excessive, no higher than 4.5k at a short blip.
Cruising around in D is so quiet though, can hardly feel the gears change either.
NathWraith
Sep 2, 2011
402
Staffordshire
More pics
Deleted member 35176
Someone has stolen my car!!!!
Very nice car mate...the spec looks excellent and so does the colour, but I'am bias.
Got any plans for it? Thinking Dark Grey/Anthracite Alloys myself but not sure.
