New handy work... Black 'S' badge and grill surround
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
olaf - I bought it from somebody who bought it in error. Saw one crop up on eBay but missed out on it. I just got lucky and happened to be in the right place at the right time to get this one. Don't think they are that expensive from the dealer mind you....?
DamoR - No worries at all, will get it to you asap :)
RobM
Sep 27, 2006
4,982
Southampton
It's sitting fine mate... think the angle of the shot makes it look like that, plus the fact it's a light colour so shows up the shadows. It's fine though :)
RobM
Sep 27, 2006
4,982
Southampton
I see what you mean, never noticed that. I thought you were referring to the black gaps either side of the S badge. Will check it out tomorrow to make sure it's ok :)
ikhlaq206
Its all about the .:R
Jul 25, 2006
347
don't know about the badge but the cars looking good
sponge bath did you say! lambs wool wash mitts here only
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Yea have to agree doesnt look like the side panels against the bonnet are sitting right. Get that checked out matey.
I do like it though :) and stop using a sponge Rob, I expect better from you! hehe!
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Did you sand the surface of the badge and surround to get a surface to key to?.
Looks very good Rob in my experience there are two things to watch out for.
1 - Get plenty of layers of lacquer (and a good key for the primer) because otherwise the black can chip off with attacks from stones etc......starts to look messy with grey primer or Chrome showing through.
2 - Make sure the black 'S' fits properly in the hole with it's new layers of paint, I lost my 'S' on the motorway must have popped out with vibration :doh:
IMO looks quite good without any badge
RobM
Sep 27, 2006
4,982
Southampton
Sponge bath was a term I used as 'Lambs wool wash mitt bath' hasn't got qutie the same ring to it ;)
Rudd - It got sanded very well before the primer went on. Both parts did in fact. Preparation is the key with things like this so I think I spent longer sanding and preparing the surface than I did on the other stages!
It had a good few coats of primer, which was then wet and dried to give a smooth and even finish. I then did a few layers of gloss black paint and then a good number of layers of lacquer, so it is very well protected and should stand up to stone chips very well.
The clever bit was being careful where to apply the heavier (if that's the right word) layers, as I was conscious of the fact that too much paint would make it hard to clip the S badge back into it's space again. It was a tight squeeze, but it's back in there now just as securely, if not more so, than it was before I started, so no chance of it popping out :D
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
Looks pretty good rob... i think i'm opposite to most and not a fan of the badge, and like to remove it...
Will be making a slatted debadge grill for a Cupra R soon... so might be an interest for you to look at... as its the second alternative for you...
RobM
Sep 27, 2006
4,982
Southampton
Yeah I'd be interested to see it for sure. But I like the fact that something is there, so it doesn't look empty.
DPJ - I've not had the chance to look at the bonnet yet, but I think you might be right. I need to work out if there is any adjustability in the catch.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
It's odd Rob, I've just nipped out to have a quick look at mine. The front of the bonnet has four rubber feet which sit on the metal member that runs behind the lights. They aren't adjustable, so unless you have to push your bonnet hard onto the catch to latch it, it's a real puzzle to work out what's up. :shrug:
RobM
Sep 27, 2006
4,982
Southampton
I can't say I've noticed those rubber feet on mine, so I wonder if that is actually the problem? Will investigate tonight and see what's up. It might be that they were taken off as part of the respray the car had recently and just not put back on again?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
If it's any help, the outside pair are about 1" long and the inner pair are shorter. You can see the marks where they sit on the top metal member.
