ND-Photo.nl 's - Seat Leon ST Cupra 280
nd-photo.nl
4,237
375
The Netherlands
youtube.com
Noticed some oil in the intake system, which is usually a sign of a bad PCV valve/system. So first things first, replace the PCV valve
AP1GczMyRdq2FJg8i2X68fRNhhBPCw1fIIYvM8q3AqySPOTOYeRq0lerl3b4hlytqpuZRq3iWWz2XTiYMZVuhaK9_6uR9J-G44va9lrv-c_D_G-i2RE0ChjZDhzL6PNuik1v6ZsQnt4wGIpwr3LAHCpCw0aa0w=w1920-h1080-s-no
AP1GczNWfyIf967It0oXUhQt48HQB5WKTdDwnf8lIQwNqSSX9RfFzemcrzwSjH70FJwlpSLZA_aTiUpou8lbEwq1iXLxIRQtB-FQZvbnnQD6h4X9d6NTj_eTwmaDLDF5A64oazN_ug_3Hr5wkKuGtX-ACo1B1w=w1920-h1080-s-no
The small hole of the cyclone
AP1GczNuxJ1OCwMx221_kwcKtzDRMzH_6W6NHZdIhavLP73BahxbtCfUzVVm2jtvszekvem940Aj9kH95ZXvtx2rHZ1zVF8OmVayyxUJeNOACvn3_fMnH2op9lptOqLmrtAoDrFNoyeuwAREOfRP6saOvvEq_A=w1920-h1080-s-no
The old PCV valve in place
AP1GczNcwX4x0t0Am5Eb-5sHvaRqhJqmqnfU50V0d0W9RixByhoswf-1c0chPU47KEhL_Wl55_5uJ-6T_P6gcz4LI9_dIHqiXRd0qUCwfya3lI1SVuO500v8VL819sbiR9pmfC_-UzIhMSxobMZEr30GK4eWzA=w1920-h1080-s-no
Old & new valve
AP1GczMUH8BHRFWJ5ZrMSFuBPV84Sw0Mm9MxwNVE805VxWuEoZTKlu7C3xxo8yAuwaLsXvOWPoLXrA1AX_wS2tMT5O2f_V8-IjEZfVphWpQTxHlZl3CJRVluUitkHyBX6HuzSL9qQlma4MXrnDYa48y7S_ACAg=w1920-h1080-s-no
PCV valve removed
AP1GczNth9klUOkeQ49gHoWSPE5sA7a08Gr1pWCqaOWBT-bhJ2dgmtnyqsaXNPe-8cK6pocYaV7dBSJW_6xbWte_M2qJk8RIXzGtteSRRXgNgXnfZXaIg2QEP9H9gCECcPdeUzibKw_nzoX62iELO823fo8DBg=w1920-h1080-s-no
New valve in place, and documentation updated ;)
AP1GczNPDQybMtm9jwHqLpQlWYUp7MIAqz_w8RvsUFgU9wCS_kXDzO4G1_GJaTrv2Ig1zSN4UWVzu8CUrc8OOSTP61UXkaCwB-clalUvlcwWHQH6V0scxq9BzVD1MnRyaUhk3_PPQHQ6xgNmysepbDvBtoBvtQ=w1920-h1080-s-no
nd-photo.nl
4,237
375
The Netherlands
youtube.com
Performed DSG oil & filter change. Unfortunately, the previous owner skipped the 120k km mark (I never understand why people skimp over necessary maintenance).
This was the first "big" jobbo on the Cupra. Also cleaned everything I encountered (sand/dust) during this job
AP1GczMIqe405kthXb7Db_FRLF9EpD4Qs7_mkO2a4lWaWYJtwa4r9RKuzDs6MyeOEqr4b3a_NqO4sRvg2UhQm-Bl-iGoX_hc-Tktgd3iEdWXS2GCrsySz24eEj-S2Lhl9nX25D0Dt9BeH2kQiMg_qke4lXpuhQ=w1920-h1080-s-no
Went for a kit from Febi (6 liter oil, filter + gasket, plug and crush washers)
AP1GczMDRJsDIXlRjSr2s0zQ5PrZ4J43StO5oUOYNnhCBebqRLzajjSH9CQznzGGczOf-lqKJ1pNyli_SYQyvoTrK6-ZmUCjK44n7ffVMYzrAy-u-7gp4FpJiWetKY_e-BiPSAj__IzI88KC5X0bgQa_RDuxkQ=w1920-h1080-s-no
AP1GczPgqFJpe1ENyAaSTXGp8uZEbydthy378bN9ebeMNUDtbEcWHMOc64Yle2oq2ukyA9SC5B0GuDMIPou0B5xW8cOcQbU2_ZHyHomKd6eQeofMuCGu5WI6ShBxMH2PWyN8HoJTWCtv4cOLdlHo5YIuuVQW3A=w1920-h1080-s-no
Vaico filter
AP1GczOujrjO2T_HaKK5UtawkIDlpRNvjxIo_OoZ88FY9f4nb8iTyoAJGmJhNPhrBqNxm9kxbWX8jQOibGZ6_FV_yfCQJgLVgZ-XP6SyJeHpqcWTQVKFZZyHH1JYgConOZXpFP0d-STg8rnG_28NDOJV7ChFlw=w1920-h1080-s-no
Used suction pump to suck out the old oil from the filter housing
AP1GczNn6wxwUodbPNTs6NHweZkrxHPbbWPdgKNXjm42oVl6cOj03o-LFyKF_RNVklOJcD14lj2fG5TsUzm2xMOYOwvJI_TNutfaxM_4jeyViSj4kxthWgQZmhum70iagCTb1oh8iUUdk_PS2zWwiTtON59R2A=w1920-h1080-s-no
Old vs new filter
AP1GczM3bM1WiWLdZuj5JcMFCGLjO9FcNnQvYoXkuzN9Z-3_jakCOjUxFB5huEIpSkAk9HMgkHlKqiyhVeroN5MaBBWtwpQYHQzZC_fmt5-e1nuVGyzzx_MgKQ6yI42IFf95Pu5D5bSuTIeAmnDbcKeaShP8yg=w1920-h1080-s-no
Let it drip!
AP1GczPGhuvPsfVZyYieAEJhO_kVcQBrtlY333_7YTJTXgXG_8CXzXCpywb_AXwYJzL8GwPod0ydnyiYwWjIUXKq_4Bn9fjxWBfNgyqqho1F_DTY2Xh-HMMPJENYOSijBAzV11MtNH0A0a9vICX-Aes0NJxJVw=w1920-h1080-s-no
PaulusB
172
38
Nice build. Please watch out with the knockoff vcds cables it contains virus software. Also u get warnings like out off range when coding its not a real hex-v2 some times it wil messup your coding on the mqb cars. Keep up the good work.
nd-photo.nl
4,237
375
The Netherlands
youtube.com
Noticed that the rear suspension is quite corroded on both sides, but the body seems to be untouched? I will be replacing this somewhere next year.
The cutout valve is visible, I will add a 90 degree turn on it so it points to the rear
AP1GczNSnby42V1V7scRZ3GI43ChAJK6b2jxr6gIhjqMWATEY4k1bJ9Ooo2cRKnZDEa7gwoYyOR5QVDx7rksbb3TEo7YO9gWnWiRTQ9TaLK7tPOPelnBSkK8AsDtDFqTaxL3aGiQpMLvECAuPUFzjT0Db509HA=w1920-h1080-s-no
AP1GczNqc9T7jqKWKWaVu_b5jlorE_X8DKep9awWFFBP4SjhexohCt4Q2iOBV4zQ60s2aQgxPbBI95p2_dic_zgqMO5_IzDoVsp8DxyN11M0HUepUiiwVl2qEbcboLuSJ6fxjABwFs5b-JSi3yA8hplwmJv-eA=w1920-h1080-s-no
nd-photo.nl
4,237
375
The Netherlands
youtube.com
Started on the tuning essentials, removing the turbo muffler.
The aftermarket version has seals added, which looks way better. I bought this from Aliexpress and fitment is 100%. Very cost effective mod!
AP1GczOYOmoGtXF0bYH9qCjkqRG_vl2q6qUy_dj5wavKDFyhB3daEJqvTgKQuwea57DHnN54Rxn0ATLJgfe1jEhlrqG-2aPb-5zlvGBVrxninXPBTDXSYt6VMtvDHywhF8tkckoyry3LYybXIJnIakrdbDERzA=w1920-h1080-s-no
AP1GczOr4QJCH7QUokzG9rwGvyea60UDyx0xXYruMA8TmwtNXnjnjtADiNAc56QZ1U95jPxwDKWhw1vt-VlOVwRgrB9-G3_4NTqNQyI1kMxHGONvUP3wJ1xCAD1ApVSR8TJ47TG4htJ86zTxQPefueTF3XawRw=w1920-h1080-s-no
AP1GczPorbmto3US0z4i2qLF7ErtKjt7jSwxaVKy9MgJUBKhko5JhhStCDqTJBwbqPsdQy6Y0UBY6mw5vLX-ec4yRAO25RxyBazArFklUHQyO9jfifeGO8pTg0Xl4527h9IzaZs1TWVHjzHPg_NwxVfxbDhDNg=w1920-h1080-s-no
AP1GczOluAnIDK2Ab3B2nOtxnm0ii58NKUbrwRZNpN_-Q_BahFUSSTA9ryJ6Ie9BnKoVJAQhGTAIBCVW93boS35bWEgM0An4Eo7yX67RXrkmJt-rzdfwligYGDs4Nr_UcrembGUvk68MgW4d0r8ZQ00GEDOJCA=w1920-h1080-s-no
Muffler delete in place!
AP1GczOSwPFswpjU47QfdX2ag7_ktQM3tRskdPdkciwv2OvnDFCaOnDFw1uAClceiTmprJWHl9zRJN8oGqUu-hl0iolQfLnWThiSAE4KcI0L-x2eM3r8Tgpxmfjwvc5V9yxFD6sbDBTrBOMhTcrttK5kvA2JOg=w1920-h1080-s-no
PaulusB
172
38
Thanks for the link. Its Common that the subframe and rear arms rust allot after. My seat garage did say to me that after 5 years many cars had the rear arms already replaced but the are not so expensive. Golf 5 and 6 have the same problems. My subframe had a rust prevent maintenance like 3 years ago. The rear arm look like the been replaced one time. The turbo elbow and hose upgrade are also cheap to do inluding a good quality replacement filter. And removing the snowgaurd out of the airbox. For stage 1 remap it give me on the dyno alsmost 10 HP. Same as al the name brand intake system with stage 1 :)
Reactions: nd-photo.nl
nd-photo.nl
4,237
375
The Netherlands
youtube.com
Also replaced the intake hose for silicone. I needed to trim the hose down a little but for everything to fit. In the end I decided to put the stock hose on again for now. The reason is that the silicone hose is not rigid and can easily collapse.
I will buy the Do88 intake hose once I also buy the Do88 intake.
AP1GczO4CEuxPz0AID9NzoKTvWwqU765xILAswMJXkJLTKxYkRJmP7D0sQ9ZLezx7LcGgqaNfNbG2WhGLaePR0kUXa3KcoLV7PNtZgZC0CRj_LfTBvmTuLeN3vQhPl3doeGEs2NYCUpnRt-YVsOeBDjCvSv-IA=w1920-h1080-s-no-gm
AP1GczNbGEll0p5LKf8-CNM-GQVjZxBthKTlFDlN_Epm-pR0xAKsjfkYNYjb1HUdc22NC3JxnpbA2qsXUIDrTlKsj2yPZrwa6-PEuwtMTMVAfgnRiO6oC17hp9EDgKo7qVoZrE69otAslyf7sO7L70d_dindAA=w1920-h1080-s-no-gm
AP1GczMpV3D10bVTvJbhhvBlQmQO4DXgYf5AKidlNSCyemztKOlZpKDSzwlR_O-wqnsVIIKsvA8UAEKdhgfrQUME-kyLLm41L4JRz-qv5hMdmxjMh30a3JbkGK64b-Kjg2tI7-ufmbjBE70aSThZwxgKOihxVw=w1920-h1080-s-no-gm
