My Revo stage 2 MK5 VW Golf GT TDI GTI Edition 30 replica - now for sale!!!
MJ
Public transport abuser
Apr 22, 2008
5,505
13
Manchester
m.facebook.com
I thought i'd share my 2005 mk5 VW golf GT TDI DSG GTI Edition 30 replica with Revo stage 2 as i've mentioned it loads but never really shared it.
Its also sadly up for sale but don't let that stop you reading through my progress with it!
I am selling my beloved Golf to fund something the Mrs is more comfortable driving. I bought this car less than 12 months ago because of the ease of having DSG thinking it would inspire my partner to do more driving but it seems that not only does she struggle driving a manual she also struggles piloting anything bigger than a pram.
I've always wanted a mk5 GTI but it wasn't practical to have a petrol and they never made a mk5 GTD so I thought I'd build my own as a compromise.
Alas I offer this fantastic car for sale with full service history and an endless list of maintenance history and upgrades.
The last service stamp will be filled in by myself. I have a folder full of receipts of purchased parts and costs.
I chose this car because of its high spec and traceable history. It was purchased from Layerthorpe VW in York in May of 2005 as a lease car for Lloyds TSB, the driver then purchased the car privately before selling it in some years later, to myself. I am the third owner on the log book.
The car has been meticulously maintained regardless of cost with pretty much all the work carried out by myself, a VW master technician of 12 years. Most of the parts replaced were faultless, I changed them for piece of mind.
All the common failing parts have been replaced with new parts including turbo, mechatronic unit, ABS pump, glow plugs etc
The car will come with 12 months MOT, serviced and valeted.
The last service was carried out in July and was a full service using genuine parts and vw 507.00 spec oil.
Engine:
2.0 TDI PD 16v BKD 140bhp 116k genuine, proven miles
In the past 6 months the engine has had:
New timing belt, tensioners and rollers
New water pump
New auxiliary belt
New alternator pully
New thermostat
New G13 coolant
Oil and filter changed 3 times using genuine parts, 507.00 spec oil and a magnetic sump plug. The oil was flushed first using forte treatment
Green cotton air filter
Custom cold air intake to the n/s/f grill
Glow plugs
Injector loom
New turbo and gaskets (oil changed at the same time)
New inlet manifold
ARP con rod bolts (sump removed and flushed at the same time)
I had the engine terracleaned in January when I bought it
Forge silicon intake pipes
Allard egr delete
Egr cooler removed
S3 intercooler
New air con rad
Air con regas
New pollen filter
Decat down pipe
Custom 3" straight trough exhaust with twin stainless tip
Armoured 5mm steel undertray
Custom oil catch can with inline filter
New anti shudder valve
New fuel filter
New bosch battery and tray
New starter motor (all earth points rust proofed)
Black coolant and washer tank caps
New coolant temp sensor
Boost line fitted if you want to fit a boost gauge
Stage 2 Revo technik software with the latest software revision running approximately 190bhp.
Always sees good fuel economy. 55mpg with ease when driven sensibly.
The decat does cause some mild smoke from cold start up but this vanishes very quickly once driven.
The power delivery is wicked! 3rd gear in D auto mode just pulls and pulls. I try not to use sport mode these days as it's a bit scary and wakes up the traction control!
The engine doesn't use a drop of water or oil and has no leaks.
Always used shell v power nitro +, never cheap fuel.
Transmission:
6 speed DSG box
Flywheel and clutch pack replaced by Wolverhampton VW last year
Mechatronic unit was rebuilt earlier this year by ECU-testing with a lifetime warranty
New dsg unit seal
Dsg oil and filter were replaced at the same time as the mechatronic unit
New inner cv boots
Air duct to cool the box built into the undertray
Poly bushed lower engine mounting
DSG paddle shift steering wheel
Brakes:
345mm vented RS3/Cupra R front brakes with new FEBI discs and pads, painted red and silver with GTI decals
310mm vented RS3/R32 rear brakes with new FEBI discs and pads
Braided hoses all round
Rs3 back plates fitted, painted in gloss black
Fluid replaced with genuine DOT4 fluid
G201 sensor replaced
Suspension/chassis:
Cast lower arms
JOM coilovers
Poly bushed front arms
Poly bushed anti roll bars
4 wheel alignment carried out
New drop links front and rear
New strut tops and bearings
New front and rear wheel bearings
New bump stops and dust covers
Wheels and tyres:
Undamaged 18" bbs ch replicas with custom centre caps and black bolt covers
Also undamaged 225/40r18 falken ZE914 tyres all with 7+ mm of tread on them
Full spare wheel kit including 18" space saver
Interior:
Full leather 5 door GTI recaro heated and semi electric bucket seats with lumbar support including leather rear bolsters and matching adjustable arm rests front & rear, door cards and hand brake lever
New GTI black carpet
Genuine dark grey VW golf mats
VW bottle opener
Euro style cup holder with sliding cover
Storage box in the arm rest
GTI sill guard trims
GTI multi function steering wheels with MFD, radio and DSG controls
GTI ball shaped DSG gear selector
Full GTI black roof lining conversion including a,b,c post trims, lights, sunglasses holder, sun visors, grab handles etc with all led light conversion
Automatic dual zone Climatronic air con with cooled glove box, rear vents and heated seats. The A/C is ice cold and just been regassed
Genuine Chrome tipped switches for the windows, lights, mirrors and fuel cap
New type locking switch
Gun metal coloured interior trims with GTI decal on
Gti chrome pedals and foot rest
Dark cherry coloured hazard light switch
Heavy duty boot liner
Facelift wiper and indicator stalks
MJ
Apr 22, 2008
5,505
13
Manchester
m.facebook.com
In car entertainment:
Standard premium 9 speaker VW sound system
Veyron VNS touch screen DAB digital CD/DVD, SAT NAV bluetooth radio with digital TV and integrated hands free phone kit.
Digital freeview tv tuner with over 50 channels
Full UK and Ireland sat nav
Bluetooth music streaming
SD, aux and ipod connections
Rear view camera
Golf GTI Highline full display clocks with full sized screen and all menus enabled everything works and is accurate but there is no glow plug light
Highline central electronics module with options in the dash menus
Highline central convenience module with options in the dash menus
Highline steering controller
Full steering controls for radio, mfd and DSG paddles
All led lights
2 new keys
Power outlets in the front and the boot
Front and rear cup holders
Genuine shark fin sat nav aerial
All VCDS options have been activated like alram chirp, brake light flash rain closing, boot pop etc
Factory rear parking sensors
Exterior/body:
Full GTI Edition 30 body kit including genuine front and rear bumpers
Edition 30 front and rear lower splitter, side skirts, boot spoiler and badges
Twin exit stainless exhaust tip
Delocked
New mirror caps
Blue tinted mirror glasses
Shultzed underside
New wipers and fan type washers
Mk6 rear wiper arm upgrade
Genuine Shark fin aerial
The bumpers, front wings, tailgate, spoiler, splitters, mirror caps, doors, rear quarters, bonnet and both sides have been painted in the last 6 months
New front wings
Coloured coded rub strips
3d vw tailgate handle
Pressed plates
Private reg R55NDS - comes with the car.
Lights:
New Retro fit 6k xenons with projector lenses
White Led front sidelights
Osram night breaker unlimited +110% bulbs in the main beam and fogs
New genuine led side repeater units in the wing mirrors
Can bus error free led number plate light units
New dark edition 30 rear light clusters with all new hella bulbs
Full circle brake light mod so the full circle lights up when you press the brakes
Factory options/added extras:
Auto lights
Auto dimming interior mirror
Automatic, speed sensitive wipers with tear drop wiping of the rear screen when you put it in reverse
Rain close function
Climatronic air conditioning
Cruise control
4 electric windows
Thatcham cat 1 alarm/immobiliser with interior monitoring, tilt and motion sensor.
Electric, heated mirrors
Electric fuel cap
Central locking
ESP/TCS
Standard rear tints
Full closure
Boot pop function so it opens off the key
In all this is a great car and it'd be nice to see it go to a good home. It's in fantastic condition but a detail and some very minor bits would have this car looking immaculate.
It's had a fortune spent on it, the wheels and tyres alone were £700 less then 6 months ago.
No **** heads or dreamers
Test drives welcome providing you are insured and can prove it.
Located in Manchester
PM, Email ([email protected]) or call/text me 07722558094 (9am - 9pm only)
The plate is free with the car
HPI clear, no outstanding finance
Will come with 12 months MOT. Taxed until jan 2015 it's only £175 for 12 months.
Questions welcome
Price £5995 ovno
MJ
Apr 22, 2008
5,505
13
Manchester
m.facebook.com
Just found a wad of receipts for parts I've purchased, the top one is for £640 worth of service parts - that's at cost price to me!!!
And the warranty documents from the mechatronic repair
holmefield
Forever messing with cars
Oct 20, 2013
578
If it wasn't for the mileage I'd have this...MJ did so vag-com work on my car is very knowledgeable on all things Vag, the golf looks like its had just about every mod done to it.
A hell of a lot of spec + goodies for the money....highline clocks O yes I'd fancy them for my leon..
Good luck with the sale....
bigbadjay
1,670
26
North Manchester
I would have it as a replacement for the 2nd car. In a heartbeat
Bout a month or two too early though. Last payment on my leon due sept
dang
Best o luck MJ
