harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
That’s good to know mate thanks, I was under the impression you needed the map pipe, but if you don’t, then great, I can always retro fit it.
I got quote today for a forge FMIC in Ireland and they wanted €678 for it, that’s with a discount which is ridiculous IMO, that’s way to much money, I know people bang on about after sales support and R&D but come on, this is all tried and tested technology. I have the below shopping list made up which should see me thru!
1. FMIC
http://www.toyosports.co.uk/fmic-ffront-mount-turbo-intercooler-type-r-550x225x64mm-6699-955-p.asp
2. 45 degree silicon 63 to 57mm long reducers x 2
http://cgi.ebay.co.uk/Silicone-Hose...arts_Vehicles_CarParts_SM?hash=item588436e458
3. 63mm alloy pipes 90 degree elbow X 4
http://cgi.ebay.co.uk/Alloy-Bend-90...arts_Vehicles_CarParts_SM?hash=item518e6b8d8c
4. Silicone coupler X 5
http://www.toyosports.co.uk/silicone-hose-coupler-64mm-25--heavy-duty-clamps-499-559-p.asp
5. Joist strap of some kind X 2
6. Washers and bolts 8mm
I will use the forge guide for removing the bumper etc..
just dont forget 1 60mm silicon coupler for the map pipe mate and your away when fitting the cooler it will sit just behind the crash bar with the top just sitting under the slam pannel cross piece, this will be the correct height to get the bumper back on, just leave a fingers gap between the cooler and rad, also rough up all the pipe so the silicon coupler has something to grab, also dont worry about pipes blowing of as mine havent and holds boost perfect hope all goes well mate will expect a few pics when done lol :D if you need any help just drop us a message mate
harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
quick update cash flow problem sorted and car is staying :D have just orderd a new tip and am trying a new air filter even bigger than the jetex when it comes, so we will see how it goes also orderd 2 falkens 452s, next is coilovers and a cat back have sold the carbon engine cover now and am keeping the bay looking standard ish just a bit of blue here and there, got myself an audi 5v engine cover looks rather good will post up when filter arrives
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
The inlet/outlet for the cooler is 57mm(2.25") and that is what the 63mm to 57 mm reducers are for, so from the cooler(57mm) to the piperwork(63mm).
And i wrong?
No your not wrong just seems a bit strange to go to all the hassle of a FMIC then having a bottle neck effect in it, especially when you can buy a cooler with the correct inlet and outlet to start with :)
harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
well all works fine for me boosts hard as plus gave me 40 lbft so got to be doing somethimg right also intake temps have massivly dropped the bigger intake size coolers are slightly wider and need more modification i thought as i dosent fit behind the crash bar
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I wasn't saying it wouldn't work I was just saying you could buy one with 2.5" inlet and outlet so less of a restriction......wish I hadn't bothered now :cartman:
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Thanks Adam, i see what you are saying and if i can find one that has the 2.5" in/oulet with the same dimensions as the one harty used then i will purchase it.
Harty, i am starting to think you are addicted to air filters, you already increased Jetex's business about 800% before christmas cause of the Jetex induction kit thread that seemed to stem form your kit, :lol:
harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
i think i am lol just hope this 1 is as good as the jetex, its defo bigger if its no good will try another, will be difficult to better the jetex tho, max on that filter was 225 gs of air on a really cold day, was imense :D hope all goes well with ur cooler mate really do like ur motor the stance is spot on this will just make it even better
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
I am still awestruck on how you are getting 225g/s, the most i have ever got is 206g/s and this was with the Jetex, fair play to you.
Also changed the stance again, i put some stretch on the front and lowered the whole car, it really makes the BBS CH look 10 times better with the stretch and they now hug the arch's very well with less rubbing.:D
I'll get pictures up when we get a dry day.
Can't wait to get stuck into my, "Fook Me Its Cold" project":lol:
harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
here is the log it is actually 226 gs
Code:
Friday	11	December	2009	13:07:04
1ML 906 032 A		1.8l R4/5VT         0001
	Group A:	'002				Group B:	'020
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME
Marker	STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF
	79.55	2160	110.5	10.88	52.33	79.06	0	0	0	0
	80.35	2480	143.6	12.92	75.97	79.95	0	0	0	0
	81.17	2880	191.7	20.06	128.08	80.75	0	0	0	0
	82.07	3440	191.7	19.72	135.28	81.67	0	0	0	0
	82.98	4000	191.7	20.06	154	82.58	0	0	0	0
	83.78	4440	191.7	19.38	166.42	83.38	0	0	0	0
	84.69	4920	191.7	19.04	182.5	84.18	0	0	0	0
	85.49	5280	191.7	19.38	201.58	85.09	0	0	0	0
	86.4	5720	191.7	19.72	218.75	85.99	0	0	0	0
	87.3	6120	191.7	19.72	225.53	86.8	0	0	0	0
	88.1	6480	182.7	17.68	225.78	87.7	0	0	0	0
	89.02	6760	175.9	17	226.14	88.51	0	0	0	0
bet it looks sick like that mate cant wait to see it get some pics up soon mate
harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
Jebus, are you logging boost also? are they 3rd or 4th gear runs? i would love to see my car hit there figures,
all 4th gear runs mate heres boost
Code:
Saturday	23	January	2010	07:13:18
	Group A:	'115
			RPM	Absolute Pres.	Absolute Pres.
		TIME
	Marker	STAMP	 /min	 mbar	 mbar
		1.2	2680	2050	1500
		2.6	3240	2150	2330
		4.01	3840	2170	2200
		5.21	4360	2160	2120
		6.43	4840	2140	2150
		7.72	5320	2190	2150
		8.94	5720	2260	2220
		10.35	6120	2190	2150
		11.66	6360	2090	2180
		12.95	6640	1970	2050
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Well i ordered most of the pipework, gonna order the couplers and IC off toyosports over the phone tomorrow to see if i can save on the shipping to ireland.
Can;t wait to get started :funk::funk:
harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
Good man, you wont regret it, the excitment nearly killed me whilst i was waiting to get all my stuff lol, bet you cant wait for it to all come :D my car felt totaly different and mor eger when it was done you could really feel the torque
Vaughny
123
Gravesend, Kent
My catch tank arrived yesterday, just need to pick it up from the post office.
harty190486 –*Where you've mounted yours, I've got a black plastic 'thing'. Any idea what this could be and do I remove it?
harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
its a relay mate it all comes apart without disconnecting anything mate, all i did was take this apart remove the case which just pulls out when you push the tab on the back, when the relay and base is clear and on its own the cable runs into the the balck casing, just hide the relay and base in there mate and put the lid on then mount your catch can there as low as you can mate fixing the catch can bracket to the car with self drilling screws if you were local would of give you a hand mate
SWANSWAY CUPRA Dealership
