It's been a couple of months since the last update so here goes........
Last few months have been rather eventful to say the least
Firstly the head was rebuilt with new guides, seals etc as required, i got it all fitted back on with the arp bolts and all was looking good, fired her up and as i hoped all was running well, after 5 mins or so of idling it developed a misfire, suspecting a coil i checked and no fault codes shown!!
First thought was it's dropped a valve, after a compression test i found cylinder 3 to have very low to minimum compression
by now i'm expecting to find a mess inside so set about pulling the head back off again, to my suprise everything was still intact, there was a very small piece of swarf under number 7 inlet valve so this could have been the
problem??
I took the head straight back to the company who rebuilt it who stripped and double checked everything they had done but apart from the bit of swarf (i'd since thrown this away) they couldn't fault it, so back to work to refit it all again, second time lucky and all was good with no faults.
I've since covered approx 4-500 miles and used no oil (usually it would have gone through almost a litre by now so i'm happy that
problem is sorted.
Next up is removing all the interior trim, i've never been sure if i could cope with a fully stripped car but now i've got the cordy (and after seeing Martin's car stripped and caged i decided i'd do it)
Me being me i decided i'd remove any wiring loom i decided wasn't required, so once again i set about stripping out interior and door looms and binning rear speakers, interion lights, alarm sensors and elecy windows.
I've rebuilt the door looms to retain only the parts i want (central locking and speakers) and the interior loom has been completly stripped and re-made loosing the bits i didn't want.
