hehe...
Not sure on the rpm range as i dont know how unitronic will tune the map.
You see you can always have some high advance in low revs to help built up some boost faster.
So i will let you know on that after the first break in and after fine tuning.
power wise well i can only imagine arround the same range as other GT28RS ibizas unitronic has built.
For example this beeza has stock pistons and IE 19mm pin rods.
GT28RS T25 and produced the following power that you can see in the dyno video.
http://www.youtube.com/watch?v=l5DZeQ57mFA
i have another mate with RS and produced 393Hp however the turbo was running out of its map i think. Not 100% sure.
I am upgrading my pistons too. My turbocharger will have a garret turbine housing T3 .63ar and my manifold will also be T3 pag parts.
So i believe most probably it will produce more power on high revs.
I didnt go with a GT2871 as the RS is supposed to be the best daily driver turbo.I aint a drag racer type of guy, but i love twisty country roads and track days . So the RS should be a better match for my needs.
Monday i am starting with the built...already booked the car with my engineer.
