Mo's Mk1 Leon Cupra - THE END....
Status
Not open for further replies.
Mo Arif
V.A.G Planet
May 5, 2010
2,510
Birmingham
Hot side:
FMIC Mounted to perfection!:
Original side mount against the Toyo IC:
Big difference
Big difference
Mo Arif
V.A.G Planet
May 5, 2010
2,510
Birmingham
The result:
T clamps could do with tidying up but that's last on my list, everything is secured, tightened up as much as possible without snapping anything.
Everything back on:
Looks ace! I'm really happy with the overall effect, Ignore the air feed, it's temp, I'm going to get 3" black air feed pipe and fit it properly flush
All done!
Verdict? well apart from the missing part pissing me off (and I had every reason to be pissed off) this is a really well put together kit, relatively simple to fit (provided all the parts are there), looks the nuts! Highly recommended.
Mo Arif
V.A.G Planet
May 5, 2010
2,510
Birmingham
Thanks mate, I always give it my 100% when messing around with car's, even though I'm not a mechanic, far from it, I work in the I.T sector.
I took it for a wee drive to shell petrol station, V-Power'd her and gave it a little bit on the way back, it was very wet, kept spinning in 1st, 2nd and 3rd! will take her for a spirited drive tomorrow!
Mo Arif
V.A.G Planet
May 5, 2010
2,510
Birmingham
Sits very nicely under the crash bar, measured up and aligned:
Forgot to mention, original inter cooler is a pig to remove, well the piping is anyway.
oldskool
Fantastic result in the end Bro, when I get mine ill pop down to Brum and you can fit mine eh?
Mo Arif
V.A.G Planet
May 5, 2010
2,510
Birmingham
well I'm still deciding about the TIP, I've read mixed opinions about the TIP on a LC here, apparently only the LCR benefits from it, not a LC
Mo Arif
V.A.G Planet
May 5, 2010
2,510
Birmingham
other then the TIP what else should I change for stage 2 that I havn't already? I might get a Forge 007p for the sake of being on the safe side and give her a full service
lynchy
143
Newcastle
your an absolute hero for the great pics and diagrams etc of the front mount. going to be a massive help when they send me the correct intercooler. thanks mate, coming along really well.
Status
