mk4 rear wiper upgrade
RachIbiza
Jeremy Kyle is my idol
Apr 3, 2008
222
Portsmouth
thanks everyone for the replies! i'll be picking up the arm and cap on friday so should be able to get the blade then too now we've got the right part number coz he said he keeps all them on the shelf, no need to order woohoo. thanks again, very helpful!
Neo
Fool member
Mar 24, 2009
881
I have the skoda fabia setup - this one
On the mk4 you need to hack about 10mm off the end of the arm, and a little off the blade to stop it hitting the 3rd brake light.
I think the polo one looks wierd and the facelift one looks like a banana!
I will take a pic tomorrow.
MadFaz
New(ish)bee
Sep 28, 2008
83
Bradford
got it fitted tonight, took 2 mins to take the old one off and put the new one on but found it hard trying to get it to move smoothly or get rid of the squeaking! try again tomorrow i guess :shrug:
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
try loosening the nut a little bit as they do not need to be mega tight
Jammin88
Fitted polo rear wiper today!! Cost about £25.00 in the end ,pretty easy to take off ,if you have problems taking the wiper arm off the bolt use a ball joint splitter ,works a treat.
Neo
Fool member
Mar 24, 2009
881
Ok, here is mine:
Skoda fabia parts, from >>This guy<<
RachIbiza
Apr 3, 2008
222
Portsmouth
done mine today with the polo one, the cap seemed to click on but it doesnt seem exactly right, what bit would i need to shave (sounds weird :cartman: ) to get it to fit really right on there?
Gooner_Mike
Teaching the kids
Jan 20, 2008
4,363
Hampshire
www.facebook.com
The bit nearest the screen. I had to trim about 5mm off the bottom becuase it kept popping up when I turned the wiper on... and it was scratching the glass too!
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,669
SW LONDON
the standard facelift rear wiper, along with the fabia one, are normal blades with a cover over them...the polo versions are the new style aero blades and imo clean a lot better
P.S - Neo > you sure that's the fabia rear wiper and not the octavia? it's mahoosive...so much so that it has 2 sections on the cover
RachIbiza
Apr 3, 2008
222
Portsmouth
ok that makes sense! so that is pops on properly and is not just hanging on for dear life like it is at the moment! good point about scratching the glass, i wont use it til i get it shaved!! thanks alot :D
Neo
Fool member
Mar 24, 2009
881
It`s from the fabia estate! Longer than the hatchback, but it`s now the same length as the facelift ibiza one after shaving about 10mm off the end.
tkjeeves
Blue
Jul 13, 2008
333
oxford
hey guy, right i've finally folded and got the full polo rear wiper after a years worth of the old steely hook arm and ebay aero retrofit special. i found the wiper arm on my car had a nasty crack on the pivot joint where you lift the wiper up anyway!
took me a while to get the wiper off after loosening the nut off due to rust and soap residue, cleaned up and put the new wiper on.
Now here my problem. my wiper arm is scratching the glass mid wipe, i've loosened the nut a bit but still squeeking. i'm just thinking i'll shave couple of mills off the arm as well as the cap, but does anyone else have this "riding too low" problem?
Feb 28, 2008
3,990
Scotland
yeh mate my glass is ****ed at the cap area due to scratching, i tried taking the wiper off to fix it but kinda cant get it off or never tried, 1 of the 2 lol, it nexer used to do it but does now, and it kinda gets annoying as you can hear it now and again, its like someone scratching a chalkboard with there nails eeeeeeeek
Gooner_Mike
Teaching the kids
Jan 20, 2008
4,363
Hampshire
www.facebook.com
Trimming the bottom of the cap where it comes in to contact with the glass is the only way of solving this. I had to trim about 5mm of the bottom of mine! I didn't really do a tidy job but its better than a scratched screen! [:@]
tkjeeves
Blue
Jul 13, 2008
333
oxford
yeah but i'm not talking about the cap, i have that problem too mine you. mine's also scraping on the wiper arm itself :( i've spent about an hour last night shaving about a mil off the wiper arm again, so when the rain stops pounding around here, i'll see if this works
Gooner_Mike
Teaching the kids
Jan 20, 2008
4,363
Hampshire
www.facebook.com
The arm!! :confused: Never heard of that before. Bit of trimming and it will be fine then...
