mk1 golf caddy/homemade 24v v6 4wd turbo
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
I have suspicions it is more than that Adam. That turbo must be flowing a hell of a lot of air at 15psi!
powernut
475
guys on replys guys , all cars and turbos have differnert flow rates and sizes as well ,
this one spools 2500rpm in decent boost at 3000rpm and will pull clean to limiter set to 7400 at mo , but will be set to 8400rpm on the track , going on a data log i did at 8psi its 250bhp riseing to 15psi 320/340bhp once its at 20psi be 400/420bhp 27psi will take it over 450 approx..... starts getting a bit hairy thow :lol:as anything above 10psi in a fwd caddy runing 2wd is a waste of time ,as it will either pull left then to right and chuffing tyres light up ,(fitted bf goodrige too ) ive tryed to get 4 wheels spining and a dam hard with old engine at 25psi
powernut
475
engines runing very well at 15psi at mo , oil temps, oil pressure, afr, timing, fueling map best its been so far ,, so thought id treat the caddy to another homemade header tank , made from alloy , as ebay prices are a dam rip off
think ill make a quick water bottle 2moz too ,, fills a hole lol
RichB11
50
Love mk1 caddy's! Was goin to get one but got Leon instead! You've mixed the two together! You're My Hero!! LOL
powernut
475
lol cheers also made a quick water bottle too ,
got a bit carryed away after making a header :laughing:
powernut
475
not mutch to add so made another for the brake fluid , im in two minds wheather i like it thow ,
then decided to skim some alloy down and make a start on the new engine mounts,
powernut
475
had a thought today ,(yes another lol) about a post eailer in the therd , about wheel banding , so i tryed one , prob is i really need 17inch 7.5j rims hard to find , so i tryed one on 6.5j rims 15inch heres how it looks
standard ones fit sound as stock on the front heres a quick pic and no rim cutting needed
evern made a jig to re line the rims ,, unsure what to do , asi like how they fit on the fronts, as the tyes wount catch the archers when i slam it
powernut
475
thew a couple of tyres on to see how they look , still in 2minds wheather i should keep alloys or run these had to fit 205 50 16 couple of pics
as it gives me a idea now ,that i need to pull the offset of the rear rims in a bit more to miss the inner archers
DannyC87
Mar 4, 2008
3,459
personally I think the steelies look far better! How have you got them to clear the front brakes?
powernut
475
i d feel ashamed to fetch this anywere lol its rough:lol had to remove the willwoods and fit stock 4motion calipairs make some adaptors but they clear the front discs by 3mm lol , ill thew some tyres on 2moz get the offset in place and buzz them up , she how it looks then , and slam it a bit more then when i found the sumps dragging ill make a custom one lol
Aimez
Ashamed?! Look how many fantastic comments you have! Most people at shows cannot say they built their car just bought bits and fitted them or got a garage to fit them. Dunno how many threads on different forums but the amount of support you have so many people would love to see this caddy.
