mk1 golf caddy/homemade 24v v6 4wd turbo
powernut
475
powernut
475
cheers , yearh the cammra man was that cold ,things didnt quite go to well for him ,, lol , sounds better in flesh ,, well more tunieing to come and hopefull better cammra man lol
Riko
MURDER WAGON
Jun 10, 2007
1,481
Milton Keynes
Weapon! Was guna mention the steam coming off that HOT exhaust, mind your passenger doesn't catch their leg on it lol!
I just have an image of you with a garage full of experiments, and knowing things people don't need to know! LOL!
Jim H
214
Teesside
My inbox has not had a thread update for a while. Have you done much to your car in the past month or so, Powernut?
powernut
475
as most know ive rebuilt the other 24v engine and it was ready to fit , and evern thow they look nice and fill a space i decided fit the early 12v mk3 vr6 which u all might have seen eariler in the pic , since then skimed some pistons down to drop compression (save useing a head spacer )
then re fitted all new valves and guides
added the mk4 r32 crank for a stocker engine
fitted new chains and tensionors to be safe
and hd crank bearings and new oil pump/filter
arp conrod bolts
steel 14lb single flywheel and cermic 6 paddle clutch
re built the gearbox
and blasterd sprayed engine
used a few pars from the mk4 r32 engine thermostat houseing/injectors/fan belt tensionor
just hunting for another turbo unit and il then make another tig welded twin scroll manifold and a alloy short runner intake , then hopefully get it runing :thumbs_up
powernut
475
thought id tempory fit , seems i have little more room in the rear
seems like there more room at the rear too :D
next ill make a shorter runner then new turbo should arrive and make the manifold all fun :D
powernut
475
thought id knock a short runner up to find ive not enoegh room at the front
so that was thown in the scrap
next only thing i caould do is modify the stock intake manifold but keep the runner lengths the same
ill just finish the welding 2moz and do of wireing unit turbo arrives
powernut
475
managed to weld rest of the intake and modify the rocker cover too
modifyed the breather and has a better idea with wire gauze and oil splash plate , which should help in boost , what a pain to alloy as the alloy contains very small fragments of hot oil and i assume over the years its contamiated the alloy , but got there in the end
fits a treat nice and air tight [:p]
also saved a good 5inch , so means i dont really have to change the sump , but i think ill make a shorter one
powernut
475
hi guys well had a bit of free time so thought id make a new coil pack mount
removed the old sensor and filled the old hole up with alloy
lump of 3mm alloy then driled a few holes
then added a 5mm lump of rubber and bolted the coilpack up to the back plate
noticed i left a gape between the timing chain cover and the back plate , save engine heat on the coil pack and added the rubber to keep it cooler ,
injectors re wired, and all engine loom wires alterd , tempord to try a start up 2moz ,,be a tad noisey but should fire up
