mk1 golf caddy/homemade 24v v6 4wd turbo
powernut
475
didnt think but i reckon this will work , first made a 12mm t3 flange
then redrilled /tapped/ground off and added a divider
then bolted it to the turbo snail , mounted and welded it on
to lift it just enoegh to get a wider return in there plus will make it better for the exhaust when the v bands arrive and ill also be able to change to run both turbos one for the road use which im fitting at mo and the other is for the track ,
welded up and fitted the turbo , and thought , **** how do i get a 19mm socket in there lol ,, thought time foe a little adapting mod ,,,,
thought ill get a allen key and weld it on the nut ,,, simple ,
fits a treat
close but bolted back up and just made another return , at a 45deg angle to 5inch down to 45deg over transforbox , and piped back into top of sump
ill have to fire it up 2moz and see if it works any better fingers crossed , heres a quick video of the old one when just reving to 3000rpm
http://tinypic.com/r/102m4as/3
powernut
475
Sounds awesome!! :cartman:
i was expecting the side exhaust pipe to be immensely loud TBH!!!
great work and skills by the way! ;)
lol nice one pal,but when i make things homemade ,my plan was to make sure its under the noise regulations,,so the best thing to was dampin the noise and the way was...............pampers nappies ,, lmao perfect and fireproof,,,,,,,,,,,,,:p
air121005
1,609
Worcestershire
:blink:.............nappies.......... where are they, in the side exhaust pipe muffler? :confused:
are they fireproof to the extent of the exhaust temps your car will be producing at peak??
powernut
475
they spot on , as there was a aprograme on tv regards them , there fire retaterdant and dont burn , fireman proved that:)
powernut
475
right this after got a bit pissed with windows not operning so instailed the lot in 45mins lol
quick check for the window switchers
then thow the moters in
then throw the lot back back , just had to make a cap for the doors cards
fitted switchers and then fitted a afr/volt/turbo timer , had to do a bit of quick chopping but all wired up and done
air121005
1,609
Worcestershire
:clap:
nice install of the electric windows!
:think:..... nappies in an exhaust:cartman:......... i bet Milltek are kicking themselves they didn't think of that.......
i'm just in awe of your engineering know how and ....... well confidence at taking on all aspects of this project!
i for one wouldn't even contemplate many of these mods...... fair play to you! [B)]
powernut
475
:clap:
nice one pal ,,, i like to like a little out of the box,,:D
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
im loving the thought of a nappy exhaust............lets hope they were new ones:cartman::ban:
still cant believe how much work and efort has gone in to this its truely awesome
powernut
475
im havin a teething problem at mo with oil bypassing into the intake and boost pipes , carnt seem to stop the problem evern with adding oil reducers,and another turbo ,,grrr other then this things seem to be getting sorted ,,,:D just going to nip out and thow some dails in dash , :lol:
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
can just see that now with tyre smoke out either side and 4 black lines as it slide's gently sideways away up the road :):)
I drove past an awesome Caddy on the M5 on my way to Swansea the other day... well... I saw a lot of nice cars..
A lovely looking red MK1 Leon FR TDi as I was going over the bridge.
A Yellow lambo Merchialargo, which hammered past me....
Oh and a lovely lovely Punto with TURBO drawn all over it....
powernut
475
bloody hell guys arsome replies ,, really glad you all like the idea ,,,, things seem to be going fine with a bit more here
first knock a hole for extra air
may leave the top part off , lol extra 4inch of cold air may help
awaiting 2 pipes to fit airfilter
then thought make a quick flange to the old downpipe job done works a treat
quick fire up and the twat spins and spools now , lol
i think ive sorted the old problem as there was a oil splash plate in this turbo and wasnt in the other , and no oil flying out now ,, left it reving at 5500 to make sure lol
next another little mod
fitted some white plazma dails , white thew day , and green or cool blue and there nice and bright too
also all the fuel system is piped up and fuel in the tank and sensor works a treat ,,,
