Missing power
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
Thanks Dan, I remember it well.
The car's been checked by two mechanics now, apparently I have no leaks. I'm just trying to arrange to borrow a car so i can send the ecu back to Will.
I feel for you mate, you will get there in the end tho:)
T7ODD
Yes, I had the brake servo hose replaced ages ago, just trust they did the work.
I've already tried a brand new N75 (my original is a 'C' new one is an 'F'), absolutely no difference.
I tried switching back to the original DV too but no difference.
seli_babe
Don't Mess....
Nov 22, 2005
409
Bedfordshire
The car seemed to be running fine before on the standard map.
I'd just fitted the Laguna intercooler and saw no decrease in boost. I was getting 8/9 psi and pulling hard.
After the remap was done, on first test drive I felt more of an urgency lower down the revs as if the car was more responsive but when I put my foot down it didn't seem to pull any harder than before but this must be due to my missing boost.
Sorry what I meant was, you should turn off revo, and see if your car is still unhappy... that way you will know if it is the map that is causing issues.
It's one less thing to worry about.
T7ODD
Update:
I took it to TSR in Bridgwater to put on the rolling road and investigate.
The printout I have is for 186bhp but they said on one run it got 194bhp and was reaching the actual boost request of 14psi.
I haven't done a log myself so don't know what the revised map is requesting.
They adjusted my actuator slightly - don't know why!
I think I need to do my own Vag-Com logs again with the revised map you put on to see what's actually going on. If it is matching a requested boost of 14psi high revs then this would explain the relatively healthy bhp. If it is requesting 21 peak mid range but only managing 14 then this would explain the slight lack of torque at 205lb/ft. I'm still none the wiser!
Todd
T7ODD
I did some logs and now I'm really confused.
Totally different results to logging on previous remap.
With the revised map, TSR is right, it is pretty much making requested boost top end but not bottom end. I thought the new map was requesting more than that though.
MAF figures look good peaking at 162g/s, although wastegate duty is looking quite high for the boost I'm getting isn't it?
I'm worried about the timing though as on the previous map I had hardly any movement on the figures but now I am. I did a torque run just for fun and got 208 lb/ft at 4200rpm.
I don't think I have a boost leak else it wouldn't be reaching requested boost at any time (am I wrong?), but I'd expect it to make closer to requested boost lower down. Maybe my actuator is a bit duff or could it be the turbo?
I have a little fin damage on the Laguna intercooler where it had caught on the bumper. That's been fixed now and I understand the fins only help to cool, the air runs through the horizontal lines which are fine. You will see I saw max 33 deg which was on it's second run so that must be working and not leaking, and the air feeds to my open cone filter are doing their job.
Suppose there could still be a blockage somewhere though, like in the intercooler or cat, or it's the actuator?
Please let me know your thoughts. Many thanks.
P.S. Can anyone enlighten me what 'injection on time (ms)' is on block 002 and whether it looks OK?
BOOST, INTAKE TEMPS & WASTEGATE DUTY
Code:
Group B:	'115					Group C:	'118
	RPM	Load	Req Pres.	Act Pres.			RPM	Intake	Load	Absolute Pres.
TIME						TIME
STAMP	 /min	%	 mbar	 mbar		STAMP	 /min	°C	%	 mbar
0.29	1920	51.1	990	1040		0.6	1960	24	1.2	1050
0.99	2000	96.2	2250	1160		1.4	2120	24	95.3	1320
1.69	2160	118.8	2260	1440		1.99	2240	23	95.3	1560
2.39	2400	139.1	2250	1740		2.79	2520	23	72.5	1900
3.09	2640	155.6	2220	1980		3.39	2760	23	69.8	2020
3.69	2880	154.1	2210	2020		4.1	3000	23	71	2020
4.41	3120	160.9	2190	2030		4.7	3240	24	74.1	2040
5	3360	160.9	2170	2040		5.31	3480	24	74.9	2040
5.6	3600	159.4	2160	2030		5.9	3720	24	76.1	2010
6.2	3840	160.9	2160	2020		6.5	3960	24	76.9	2010
6.81	4080	160.9	2160	2010		7.21	4200	26	83.5	2030
7.51	4320	166.2	2150	2060		7.81	4440	27	85.1	2110
8.11	4560	171.4	2110	2130		8.41	4680	27	92.5	2110
8.82	4800	169.2	2000	2070		9.22	4960	29	90.2	2000
9.52	5040	163.9	1940	1960		9.82	5160	29	90.2	1940
10.12	5240	157.1	1920	1910		10.42	5320	30	91.4	1900
10.72	5400	153.4	1910	1910		11.02	5480	30	91.8	1900
11.32	5560	148.9	1890	1870		11.62	5640	31	92.5	1860
11.92	5720	145.9	1880	1830		12.22	5760	31	94.1	1810
12.52	5840	142.9	1860	1800		12.82	5920	32	95.3	1780
13.22	6000	138.3	1810	1770		13.62	6080	32	94.9	1730
13.92	6160	135.3	1790	1730		14.22	6240	33	94.1	1730
14.52	6280	132.3	1770	1720		14.82	6320	33	93.3	1700
15.12	6400	130.1	1750	1700		15.43	6440	33	92.2	1720
15.73	6560	123.3	990	1800		16.03	5920	32	0	1400
TIMING PULL, MAF & Injection Time
Code:
Group B:	'020					Group C:	'002
							RPM	Load	Inj.Time	MAF
TIME						TIME
STAMP	 CF	 CF	 CF	 CF		STAMP	 /min	%	 ms	 g/s
0.71	0	0	0	0		0.4	2040	27.1	3.28	12.56
1.3	0	0	2.3	0		1	2120	76.7	10.66	38.67
1.9	0	0	0.8	0		1.6	2240	105.3	13.12	50.47
2.5	0	0	0	0		2.2	2440	125.6	15.58	63.28
3.2	0	0	0	0		2.8	2640	143.6	18.04	74.92
3.9	0	3	0	0		3.6	3000	148.1	18.45	85.17
4.61	0	3	3	3		4.21	3280	153.4	19.27	94.97
5.32	3	3	3	3		4.91	3560	155.6	20.09	102.64
5.91	3	3	3	3		5.62	3880	159.4	21.32	116.67
6.61	3	2.3	3	3		6.22	4080	158.6	21.32	123.92
7.22	6	5.3	6	5.3		6.92	4360	164.7	22.55	140.42
7.92	6	5.3	8.3	5.3		7.52	4600	171.4	23.78	150.17
8.62	6	5.3	8.3	5.3		8.32	4880	167.7	24.19	154.58
9.32	6	5.3	8.3	5.3		8.92	5040	162.4	23.78	155.33
10.03	6	5.3	8.3	5.3		9.72	5280	157.9	23.78	157.25
10.63	6	4.5	8.3	5.3		10.33	5400	154.1	23.78	158.36
11.23	5.3	4.5	7.5	4.5		10.93	5560	150.4	23.78	158.97
11.82	5.3	4.5	7.5	4.5		11.53	5680	146.6	22.96	160.11
12.43	5.3	4.5	7.5	4.5		12.12	5840	143.6	22.96	161.28
13.13	5.3	4.5	7.5	4.5		12.83	6000	139.1	22.14	159.72
13.73	5.3	4.5	7.5	4.5		13.43	6120	136.8	21.73	160
14.43	5.3	3.8	7.5	4.5		14.13	6280	133.1	21.32	158.94
15.03	4.5	3.8	7.5	3.8		14.73	6360	131.6	20.91	159.67
15.73	4.5	3.8	6.8	3.8		15.33	6480	128.6	20.5	159.44
deansibiza
dean
Nov 13, 2006
49
im very glad i found this post, ive had this problem since january and have fixed a number of small problems and still only getting boost of 10psi, i had my re-map done by a diffrent company but like your self since the map its never boosted to what is being requested.
think ill get back on to the map company see if anything can be done, i have replaced the n75, maf and many pipes with the hope i could cure it but now after reading this and having no fault codes on vag-com im certain its the map.
i also was expecting 190-200bhp and only produced 175 iirc.
T7ODD
Wow, check out those CF's!!!
Fuelling is pretty much fine, how are your plugs?
I've logged in the past and never seen anything like those CF figures before until this current revised remap (same company). The plugs were changed back in March/April. Might it have anything to do with the actuator being touched?
How can you tell about the fueling?
I don't think the plugs are affecting the boost but I'll change them if you can recommend others to try.
Strange things is that TSR (they didn't map it) seemed happy about how it was performing. Another mechanic elsewhere said that maybe that's just how the car is :shrug:
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
have you had new coil packs recently as well or you not chanegd them. i was getting some bad cf's changed spark plugs to NGK's and couple of new coil packs and all went away, will affect the boost with bad cf's as will pull timing back.
I would put my finger on a weak actuator spring before anything else? Car is wanting more boost but the actuator can't keep the wastegate shut so your bleeding off exhaust gas? Seems like the "easy option" to me?
I don't know if this will work on a cupra -- My friend showed me the trick once... take the vacuum pipe off the actuator and attach a foot pump, push down on the foot pump and if your actuator opens early (ie a lower boost pressure than it should) the spring is a bit weak? Does that sound plausable?
T7ODD
Thanks for the very helpful input guys.
I could blame fuel, I'm running on 95 ron and am unsure what it's mapped for.
I don't know about heatsoak, the intake temps seemed pretty good to me (unless that's different to heatsoak).
The actuator has been my suspicion all along but I've had two attempts at fitting my Forge actuator. It looks like a turbo off job though to me which would probably take about 3 hours garage labour. I does seem like a weak actuator spring but sureley TSR would have seen on the rolling road whether the wastegate was opening/closing properly? That's why it went there.
The blocked cat has been an option too as it was a bit smelly but has been OK for a while now and passed emissions in April.
T7ODD
Also consider a blocked cat if your on standard downpipe and a wound out actuator.
When you say 'wound out' do you mean wound towards the actuator rather than the end of the rod?
I understand I'll be making the spring stiffer by winding it towards the actuator. Shall I wind it all the way and do another log? Surely fueling will be OK as long as it's not reaching over the requested boost levels?
Sorry for being a bit naive about these things but I need to decide whether it'll be worth spending £75 on labour putting the Forge one in. Many thanks.
