Mark's Black LCR 225
Mark300zx
1,458
8
Surrey/SW London
Fiited 2.0T coil packs today with the adaptors and BKR7E gapped to .040", on tickover it seems like a different car and it feels a lot smoother doesn't seem to be any gains in acceleration but the ecu has still got to adapt to the new setup!
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Nice...been hearing more about these coil packs being fitted to the 1.8T's
Feb 20, 2010
1,525
ipswich
So what are the benefits of this
Mark300zx
1,458
8
Surrey/SW London
Ok just replaced the battery with a Bosch Silver line, I used have a problem with a door solenoid now it has magically disappeared, which makes me think that the battery I had was under par or knackered for a long time!
Mark300zx
1,458
8
Surrey/SW London
Changed from the green to yellow spring in my 007, must admit noticed a difference straight away, even surprised me when it span the wheels coming out of a junction!!!! :)
Mark300zx
1,458
8
Surrey/SW London
Job of the day was changing the injector seals, a couple were leaking between the manifold and injector, swapped them over and the car is definitely perkier, also cleaned the throttle body and air inlet temperature sensor as well!
Mark300zx
1,458
8
Surrey/SW London
A few more updates fitted in the last few weeks at 72,400 miles.
New Air filter fitted
New Wideband O2 sensor fitted, it wasn't flagging up as defective but after investigation it seems they have a lifespan of somewhere between 60-100000 miles. I changed mine as I know the egts are high on the lcr and will knock the stuffing out of it. I am glad I did as it completely changed the character of the car and I think it will repay itself in terms of MPG and engine safety!
Fitted a blueflame exhaust and scorpion decat pipe, along with spacing out the 02 sensor with washers (will see if this works in the summer). Not very impressed with the fitment of the blueflame it hangs low at the rear and potentially fouls the subframe tunnel, but to be fair I am not sure if this is decat pipe throwing it out of alignment. Sounds good initially a little raspy but as it carbons up this seems to quietening down, spool up is quicker and the engine seems freer to rev!
8bit
3,401
Aberdeen
The done thing would be to ask you to post a video so we can hear your new exhaust but given the lack of pics (hint!) in here I guess that's unlikely! ;)
Good result on the exhaust tho :)
Mark300zx
1,458
8
Surrey/SW London
