How do I test the piston mate?
And it's not just 7psi it's ~21psi down to 10 then drops to 3 and sometimes 0
are the r users using 2.25 strait through or are they reduced?
how bad does the car feel dan??
Thats a monster boost leak mate? can you not hear air escaping?
If not could it be a boost valve [n75?] fault?
test the dv dan, only takes 2 mins....
you checked the vac pipes under the inlet manny?
if peaking at 10 psi only, maybe n75 fault... you looked at the pipes from n75 to charge pipe?
Which pipe is this mate there's so many in the bay I'm lost lol Got a pic to point these vac pipes out would help alot
N75 is the one that goes to the charge pipe.
I used plastic cable ties mate
