Remove the wipers, if they are tight pour hot water over the spindles something magical happens and they are able to be removed easier.
Then lift of the scuttle panel, also remove the rubber.
That uses the same foam as the door seals.
Betcha mine is the same...that foam should be banned...
Glad you sorted it
Brian
make sure all the dirt and leaves are removed and check your drain holes are not blocked.
its all perfectly clean , drain holes are clear , i hope it was this foam seal around the plastic covering the wires into the car ,, ( not sure of the name of it )![]()
Or the pollen filter surround hasnt been fitted correctly. Water pisses in if this is the case. Have you had the car serviced or screen changed recently?
