looking for a guide to remove scuttle panel
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Remove the wipers, if they are tight pour hot water over the spindles something magical happens and they are able to be removed easier.
Then lift of the scuttle panel, also remove the rubber.
ozzymyster
234
When removing the doors I know it's advisable to have spare door clips because they tend to break, anything similar for the scuttle panel?
Brian
Sep 4, 2009
736
its a seal that presses into a groove at the bottom of the windscreen. should just pull out. Make sure its pressed firmly back in all the way along when putting it back on though.
BEEFYGTI
625
Port talbot, south wales
sorted, i think i have found my leak, underneath the scuttle panel near the bonnet release there is a huge black plastic piece that is sealed with a foam, this foam lifts slightly and so I hope and wish that this is where my leak is from, I have sealed this and got my fingers crossed
rs-tuner
321
stoke-on-trent
its all perfectly clean , drain holes are clear , i hope it was this foam seal around the plastic covering the wires into the car ,, ( not sure of the name of it ):shrug:
sounds good alot of the time the drain holes block and water rises and pours in through the pollen filter and around the bottom of the pollen filter housing.
turboboy
Limp Mode Squad ™
Dec 9, 2003
2,007
hants
Or the pollen filter surround hasnt been fitted correctly. Water pisses in if this is the case. Have you had the car serviced or screen changed recently?
BEEFYGTI
625
Doors have been done fella, just coming from the front of the car near the bonnet release, we are due rain tonight so I will await my morning footwell pool in the morning ! ( unless it's fixed)
