Leon Short Shifter
t10akE
Complete Member
Feb 22, 2002
217
Walton On Thames, UK
well i checked my shifter arm (?) last night and it is indeed a pin type fitting on MY03 Leon Cupra's. I shall therefore be ordering my shifter in about 10 minutes!
:cheers: Tim
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
junior munky said:
How does the side to side reduction work then ?
Olly.
. :cheers:
I imagine it makes it move less side to side :rolleyes: So, not only does it reduce the distance between 1-2, 3-4, 5-6 it also reduces the distance between 2-3, 4-5 as you're moving the lever across the car. Does that make sense? :confused:
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
No that's not quite right is it. The throw between 2-3 would be still be reduced without the side-to-side reduction, but it would be reduced more with the side-to-side reduction.
nd-photo.nl
3,668
22
The Netherlands
www.nd-photo.nl
Yeps had that one as well, awesome piece of kit.
eBay short shifter by Andy Ramdin, on Flickr
Put a large pin or nail in the hole on the bottom right. Also secure the gearbox by pushing in the pin and pushing in the gear lever (you can also do it without).
Shifter by Andy Ramdin, on Flickr
Remove the bolts and pieces
Stock shifter by Andy Ramdin, on Flickr
Side by side comparison
eBay short shift vs OEM by Andy Ramdin, on Flickr
Fit the kit and enjoy
Short shifter installed by Andy Ramdin, on Flickr
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
It is ain't it, fook paying £100 odd quid for one, that's just a crazy price to pay.
shanky77
31
Ipswich, Suffolk
Have a little look through this thread - very tempted to have a little go at this myself, just gotta hope the grabby things don't break when doing the cable reset.
EDIT - can't post links yet grrr - search this forum for 'DIY short shift' and you'll find it
shanky77
31
Ipswich, Suffolk
I would say cables need a reset after this as its likely they've stretched changed a bit over time anyway, read about people really struggling to select gears until doing the reset
bruceR
2,558
647
Monifieth, Dundee
YES the cables do need reset.
Go on Forge website, click on OTHER tab, then QUICK SHIFTERS, then download PDF for the relevant shifter.
Bigjohn84
May 5, 2015
2,330
Ma bad well I didn't need to do mine and it's been fine ever since I got it in??
doski
40
Warwickshire
I know you like yours but are they good quality? been watching them for a while but don't want to spend money if i get it in my hands and it doesn't feel solid enough
Bigjohn84
May 5, 2015
2,330
There good enough mate the guys sold 109 so that must say something there, I've had no problems with mine mate, and ND-PHOTO had one also so that says something
