Ben CTR said:I doubt very much he ran a 14.2 STANDARD mate. I seem to remember him running a 14.3 with Remap...
he mentioned it on the clio vs revo LCR thread
http://www.seatcupra.net/forums/showpost.php?p=813947&postcount=7
Peak power was at 5850rpm and peak Torque 3500rpm. The torque Curve does tail off very very slightly, but not a massive amount really... The car pulls well all the way to about 6500rpm to.
If you're at Pod this year mate. I'll give you a run.... ?
Haha alright mate !! I wondered how long it would be before you got here, you trading in the punto and getting a real car ?
Mine doesn't overboost to as much as 20 psi more like 18 psi... you are right about the agressive overboost, but don't forget though that is on a K03, the bigger K04 and twin intercoolers does help matters a lot !!
As much as I like the LCR don't bother at Santa Pod, you will get cained down the standing 1/4 as its all about the launch and the non-lsd seats don't really like launching (although i did get a 2.19s 60' once)
Not sure I agree with the Fiat being the best handling car (along with a corrado ??!! nice 1975 chassis !!) that big old lump of, odd cylinder, unbalanced pig iron you call an engine can't be good for the weight
My best mate used to have a Fiat 20V Turbo and although it was extremely fast in a straight line (sounded like Darth Vader when flooring it in first) he used to say it handled very poorly. While he'll admit that down the strip it would have beaten his brothers CTR and my other best mates Integra type R, he admits that it was no way near as planted on corners...He say's the best handling cars he's ever driven (handling wise) are his old clio williams, Integra Type R and FQ340.
The lag is very bad, he has had problems with old grannies at the lights etc, infact, I left him for dead in an MGF at the lights (traction much better) up to about 80.
I think it definately requires a sixth gear, as in the special edition one. As someone mentioned earlier, the 0-100 is quick because of 3rd running to 100. I would imagine always having to drop a cog to get the thing moving in normal day to day driving. I think torque at the wheels is related to power x rpm, therefore, 6 cogs result in more torque produced at wheels more often???
I think it looks pretty good even now, and actually seems like a special car when you are inside or out. Something the R is not.
Overall, I think the R faster more of the time, the coupe only excels in a few stat orientated areas e.g. 0-100.
Yes, I am!! torque at the wheels is a relationship between gear ratios and torque produced. I was getting confused with power LOL. However, my point was that the long ratios left the coupe with an in gear acceleration problem. Does this not still apply?
S1MMA said:The long ratio's in the coupe means that you have to select the lowest gear available if you want to accelerate very hard (above 2500rpm anyway), so you are right about that, pootling along at 2000rpm in 5th a coupe is not going to lunge forward if you floor it. Shorter gear ratio's do give better acceleration due to higher torque at the wheels, although the trade off is that you can't hold that harder acceleration as long as a longer gear car (with the same engine), so where you change up - the longer geared car holds another x mph at now higher acceleration than you (as you've changed up). hope that makes sense, its a trade off, shorter geared cars do accelerate harder, but require more gear changes to get to x mph. Cars that rev higher (like an S2000 for example) take advantage of having high torque to the wheels in gear as they can get away with having shorter ratio's as they can still hold acceleration to the same speed as a car that doesnt rev as much - but has longer ratios. I know this isnt written very well (I'm trying to make it simple), does it make sense?
No one is bickering, you guys must be very tame if you think this thread has got out of hand, its a good discussion IMO. Just puttin the facts across.
S1MMA said:No one is bickering, you guys must be very tame if you think this thread has got out of hand, its a good discussion IMO. Just puttin the facts across.
Tallpaul said:well i think this thread makes a nice CHANGE from the LCR v CTR threads.
I'm not bored, interesting to here an owners opinion of a cars performance rather than the usual 'i thrashed one on the dual-carriage way, therefore they are slow and sh*t' comments.
S1MMA said:Some people can't see beyond what they own or appreciate what's out there, or they're just too f*cking stupid and just open their mouths when they don't know sh1t. These people usually are the ones that ruin this type of thread, shame really.
S1MMA said:peak torque is produces at 2500rpm, but yes I know what you mean by the 3000rpm comment.
There is more turbo lag due to the turbo being different on the Fiat Coupe (than say a K03 or K04), it's got a garrett T28 turbo (same as the Nissan 200SX or Escort Cossie). Just a characteristic of the turbo really, there are options of hybrids with faster spoolup avail if you want to go down that route. Really speaking, cars like the MK5 Golf GTI or most stock 1.8T engines dont produce much boost standard so have smaller turbo's - which are good for spoolup but not great for holding boost high up in the rev range. So again, its give and take in this area also.
