Nice vids m8 love the Volvo in post 81 what a nutter
Still FWD with wavetrac LSD and running dot tires:
http://www.youtube.com/watch?v=pNru9_a2S8A
Still not happy with front grip so I'm changing to slicks next summer.
The original BAM engine blew up because of an aggressive remap and no oil cooler. Oil cooked and so on..
Just on the front axle mate. Never had grip problems on the rear of this car. Ever. I'll start off with slicks front and street tires rear. Then Dot tires rear if it becomes too hairy![]()
Hey! Trial and error right?
Be very interested to hear how you get on with slicks on the front and treaded on rear as I have considered doing that on the track.You mention Dot tyres on rear if it becomes too hairy, what exactly are Dot tyres? are they somewhere between a slick and normal street/treaded tyre?
What's the equivalent size to the slicks in road sizes?
When I get another set of wheels Im going to try slicks out
Great work
in theory, if i'm not completely wrong:
slick 210/650-18 is equivalent size something like road 210/45-18
road 225/40-18 is equivalent size something like slick 225/635-18
road 235/40-18 is equivalent size something like slick 235/645-18
this is theory.
look forward to hear about your experiences Gulfstream.
I thought you already had a billet wheel? Been thinking about slicks for mine for strip days.
Davs Allan,
You're off by a bit:
210/650R18 = 225/40R18. They have both approx 20cm from rim edge to rim edge
the "width" size of the tyre has nothing to do with the tyre width at the rim, its only the width of the tyre. and even then the "width" size of the tyre is not necessarily the same if you measure the contact area of the tyre to the road.
if you look at road tyre sizes and racing tyre sizes the only difference in theory should be the height.
road size 225/40-18
mm width / percent height - rim size in inches
width: 225mm
height: 90mm equivalent to 637mm complete tyre height
rim size: 18"
racing size 210/650-18
mm width / mm height complete tyre - rim size in inches
width: 210mm
height: 96mm equivalent to 650mm complete tyre height
rim size: 18"
so the 210/650-18 is only a little bit higher then your 235/40-18 tyres, and some what higher then 225/40-18 tyres. so you get more topspeed in top gear/max rev.
not saying that you have the wrong size or anything only trying to explain the theory and numbers on paper.
Gulfstream
like your gps/laptimer in this youtube video
can you tell me more about it?
