I cant see it being a leak, if you floor it from low revs you gets a fluctuation in boost, if you gradually depress the trottle to the same position most the time its fine and will hold the correct boost level - which makes me think its not a leak as how could it hold the correct level where it normally bounced - so its basically a problem when initial high boost is requested.
Also when full throttle from higher revs its seems to be ok most the time.
Everyone agree?
Everyone agree?
