paul-murphys
efr 6758 here i come
What kind of torque was your engine producing with those mods?
Connecting rods in BAM engine should be quite fool proof up to 300lb/ft.
These incidents makes me thinking limiting the torque of my Ibiza MK4 Cupra, which has even weaker rods than the ones used in BAM engine :rolleyes:
had a few rr printouts with the 300 lb/ft mark, im uprating engine so this dont happen again
paul-murphys
more pics
my new clutch and flywheel only on car for 40 miles
pic of back off engine
what rod meant to look like and what mine is
wild willy
2,323
Wales
Paul, the high flow manifold replacements ae due out very soon, maybe worth holding out to refit one of these. Do you have any RR graphs of your torque levels since you uprated the actuator.
paul-murphys
have looked into these once see gains may go for one. dont think will have to limit torques as engine having uprated rods put into it, also looking at water meth kits,
paul-murphys
hi im taking other 2 out today an will see if there bent as well, im changing exhaust valves an inlet an also the springs just waiting for a price on some parts from the us from guy thats building engine, i want a super strong engine lol, going to take time an pay for all bits to be replaced on engine then refit it with new engine mounts metal water pump an maybe a kevlar timing belt, may hold out for the high flow manifold once see the gains,
filbro
337
Derbyshire
Wheels look really nice. I think your motor would look better if you lost the window tints, break up the black theme a bit??
Good luck with all the rebuild. Once its done you'll have a real weapon :)
