LCR possibly on last legs - Head Gasket Gone
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Well thought I'd post a little update as had another look at the car this evening and it seems the car running ok was a fluke as took the car for a little drive, less than 400m, and smoking like a biatch and temp sensor got up to 90 degrees in that short amount of time.
Got back and checked under oil cap and mayo starting to form so pretty much proves its the head gone...hope there is nothing else...... :(
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Will check that in a bit. Cars gonna head of to TTS, as they are local to me, hopefullyover the weekend if not sometime next week. Its gonna hurt my pocket this is.........:(
D.K
LCR 225
Oct 24, 2007
6,408
se london
Try not to drive it inbetween mate, If the head has gone and it over heats you could do a lot of damadge, Also ask them if they are going to skim the head when they do it.
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Check for air bubbles on the dip stick aswell
No bubbles on dip stick that I can see its all covered in black stuff..........;):p
Smell the coolant tank too.
Well the coolant has a burnt smell to it and no doubt whats causing the smoke now as smells the same.
Spoke to TTS this AM and they went through the motions of what will be done and they said when it is all stripped down they will assess the head and get it skimmed if needed.
Cupra Ross
Breaks things............
May 15, 2005
1,379
Edinburgh, Scotland
I'd be inclined to put it down to turbo seals. A blown head gasket on a 72k 1.8T without an underlying overheating problem is pretty much unheard of, in fact a blown head gasket on the 1.8T is almost non existent in any circumstance.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
I was told once by a dealer that HG was common after 60k, but as said its not something that comes up on here.
mrwookie
Big Daddy...
Mar 22, 2008
716
Cambs & Herts
Well if it is headgasket going to enquire about having a metal head gasket fitted, if they do them for the LCRhad one fitted to my 200sx, or if turbo then hybrid here we come................
