knock from front suspension
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
you should have a metal bracket to hold the RUBBER bush steady and yes the ruber is open so you undo the 2 13mm bolts remove the bracket and rubber will pull off and replace :)
kris_tdi
108
its not the bush, between the bush the the metal bar there was a plastic collar. its this which has broken and caused the bushes to be loose, not the metal bracket.
rashcupra
Oct 15, 2006
6,517
crawley
im not aware of this plastic collar then as when i had my arb apart i only saw the rubber bush the metal braket and the 2 13mm bolts :think:
it should have a slit to allow you to replace it
